I recently bought a close up filter kit to try playing with macro. The man at the camera store said that the close up filters would give me as good results as using an extension tube. I'm not sure? I have been considering getting the kenko extension tube set until I can buy a "true" macro lense. Below is a photo I took of an iris with my 70-300 lens with a +3 filter. I mounted on a tripod using mirror lock up and a remote shutter release.
If I get the kenko ET set would you use the tubes along with a macro lense (say the Canon 100mm 2.8)? I'm not sure if the tubes will be needed once I get a macro lens and don't want to spend the $159 for the set. HELP!!!
