Thread started 23 Jun 2006 (Friday) 09:51
RAM Upgrade Help
nation
Joined Jun 2005
Jun 23, 2006 09:51 |  #1
Dear All
Any help finding my way through the maze of RAM upgrading would be much appreciated :)
I'm using a Sony Vaio VGN-A115Z laptop in standard form and want to upgrade RAM. The first link shows the current setup and the second link is Sony's upgraded RAM specs:
http://www.vaio-link.com …tegory=-1&serie=-1&m=1674 (external link)
http://www.vaio-link.com …mpat.asp?l=en&m​=1674&c=10 (external link)
Rather than pay Sony's extortionate prices I want to look externally for RAM upgrades; Kingston, Kingmax, Buffalo, Transcend etc. When looking at the other brands what is the identifier I need to look for to determine if that RAM works on my machine? Is it the SO-DIMM - 333Mhz (DDR), PC2700 DDR SDRAM, DDR333 that appears on the links above? Anything else that I specifically need to look for to ensure compability with my machine?
For your info here's a list of RAM options available to me peppered with acronyms that mean little to me at this stage :):
http://www.jumbo-computer.com/pricelist​/pricelist.asp (external link) (dropdown menu for RAM)
Also I understand PC2700 has something to do with speed?? Am I limited to PC2700 or can I go faster when choosing RAM? Finally, it says my machine can only be upgraded to 1GB of RAM (2 slots of 512 MB). What would happen if I went beyond 1GB? Is it simply that my processor won't be able to take advantage of the extra speed or are there other adverse effects like my computer exploding?
Thanks all :)
7D and lenses.
Woolburr
Rest in peace old friend.
Gallery: 115 photos
Jun 23, 2006 10:15 |  #2
Go to Crucial.com and use their system...will tell you what ram you need. I have had great luck with them over the years.
ArcticEOS
Jun 23, 2006 10:55 |  #3
If you ever need to know about a component in your computer or on your motherboard, CPU-z is a great tool to tell you what you have and what you need. Its free too! Here is the link http://www.cpuid.org/c​puz.php (external link)
My Nature & Wildlife Blog (external link)
For members of POTN, I am offering custom designed photo galleries starting at $150. Need a website? Let me know!
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jun 23, 2006 11:20 |  #4
You must use PC333 (2700) 200 pin SO Dimm,s
Sony is saying the max RAM is 1GB.. why I don't know... ???
If this is true than you'd be buying two 512 sticks.
Perhaps though it will work fine with a pair of 1GB..
But this is most likely a limitation of the MOBO bios.. so probably not worth trying.
Here's the stuff at Newegg (external link)
CDS' HOT LINKS
SimonG
Jun 23, 2006 12:06 as a reply to  @ CyberDyneSystems's post |  #5
CyberDyneSystems wrote:
... Sony is saying the max RAM is 1GB.. why I don't know... ???
But this is most likely a limitation of the MOBO bios.. so probably not worth trying. ...
The memory limit is due to limits within the chipset / memory controller. You may be able to put in larger sticks, but I wouldn't count on it (and even if you did, chances are the memory controller wouldn't address more than 1 GB worth anyways, if it worked at all). That said, there's no reason why you need to put in PC2700 memory, since memory is backwards compatable; you could drop in PC3200 sticks or better, and they would just run at the slower speed.
-- Michael (a.k.a. SimonG)
EOS 5D | 17-40 f/4L | 24-105 f/4L | 40 f/2.8 | 50 f/1.4 | 85 f/1.4 | 430EX | Zenfolio (external link)
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Jun 23, 2006 12:07 as a reply to  @ Woolburr's post |  #6
Yes, and crucial is one of the only manufacturers that actually makes their own RAM. Great memory and easy upgrades.
Doc Klepper in the USA
I
nation
Joined Jun 2005
Jun 23, 2006 12:29 |  #7
Thanks for the advice. Clears up a lot.
I had a look at the Crucial site earlier and it was very helpful. But the thing that threw me was that they said my laptop is upgradeable to 2GB contradicting what Sony and a few other sites said. I just wasn't too sure whether putting in more than the maximum would cause problems or not.
7D and lenses.
1,067 views & 0 likes for this thread, 6 members have posted to it.
RAM Upgrade Help
1508 guests, 130 members online
