Thread started 26 Jun 2006 (Monday) 16:12
Arrrgh! I'm so close...
AirBrontosaurus
Jun 26, 2006 16:12 |  #1
...to useable reversed-lens macro shots. For thie life of me though I cannot work out the DOF. It is nearly pitch-black in the viewfinder, yet the DOF is still way too shallow!
Anyways, this is what I have so far. They look pretty bad, and the detail isn't there at all, but I think it is a step in the right direction. There are all uncropped (resized) or nearly uncropped.
Here is a mosquito that tried to feast on me:
This is a fly whose head got cut off in the picture (uncropped. Just resized):
And finally, here is a another, smaller fly whose compound eyes came out pretty focused (too bad nothing else did). Again, nearly uncropped:
Thanks for looking. I know there aren't very good shots at all, but I keep feeling this urge to go out and take shots with the reversed lens anyways. Eventually I hope to get workable reversed lens shots. Until then, I just have to keep experimenting!
Chris | My Flickr (external link) | AirBrontosaurus.com (external link) | Peleng 8mm Fisheye writeup (external link)
Body
: Canon 5D
Lenses: Canon 24-105mm f/4 L | Canon MP-E 65mm Macro | Canon 85mm f/1.8 |
cgratti
Lord_Malone, your still a newb...
Joined Feb 2004
Jun 26, 2006 19:31 |  #2
No exif data for your pics, so I can't tell what your settings were on your camera. Are you shooting at or about f/11 - 13? That will help with DoF, shutter speed should be about 1/200 sec..
Canon 30D
Canon 10D
Canon 28-105 f/3.5-4.5 II USM
Apple iMac G5
AirBrontosaurus
Jun 26, 2006 20:41 |  #3
Yup. Aperture on the reversed lens is f/8, and on the forward lens is f/8 as well. All shot at 1/200th shutter speed.
The problem is that with the smaller apertures on the reversed lens, the viewfinder becomes almost pitch black. Anything past f/8 is nearly impossible to see.
Body
: Canon 5D
Lester ­ Wareham
Moderator
Gallery: 3035 photos
Best ofs: 5
Jun 27, 2006 00:46 |  #4
You could add some focussing lights. I use the twin flash with the MP-E 65mm at high magnification. Often it will be so dark you can not focus without the flashes focus lights, just double tap the shutter button and they come on. If you are stuck for budget you could try a small but bright tourch strapped to your flash.
Macrophotography by LordV
dpastern
Jun 27, 2006 16:55 as a reply to  @ AirBrontosaurus's post |  #5
Open the reversed lens right up, as wide as possible so that it lets as much light in as possible. Your usual lens stop down to around f11. That's why it's so dark ;)
Dave
AirBrontosaurus
Jun 27, 2006 19:04 as a reply to  @ dpastern's post |  #6
Dave
If I open up the reversed lens, them my DOF gets a ton smaller (at least, it seems like it does). If I'm correct on this, even if the forward lens is at f/11, but the reversed one is at f/1.6, then the 1.6 limits the DOF and the f/11 does nothing. Am I wrong here?
f/8 is as low as I can go without the viewfinder being pitch black (unless it is very bright outside).
Body
: Canon 5D
AKRover
Jun 27, 2006 19:15 |  #7
I am so going to try that as soon as I get home, I don't remember reading that one in the manual. I hope it works because it is really hard to keep the subject in the view finder at 5x and reach up to hit the lamp button at the same time. Thanks for the tip!
dpastern
Jun 27, 2006 21:08 |  #8
My understanding was that the reversed lens was opened right up and not stopped down. I could be wrong, I've never played with reversed lens before...one of the other guys will be able to definitively answer your query I suspect!
Dave
AKRover
Jun 28, 2006 03:22 as a reply to  @ AKRover's post |  #9
Well darn it didn't work. Would it be because I am using a 10D? I was so excited too.
LordV
Jun 28, 2006 07:12 |  #10
AFAIK Dave is right- you should open up the reversed lens and shut down the primary lens to F11 or F13. That's how I used to do my higher mag shots before I got the MPE-65- just think of the reversed lens as a high dioptre filter attachment lens- no aperture diaphragm on those. Think you will find the dof will be better but it's very narrow at high mags anyway.
Brian V.
Macro Hints and tips
AirBrontosaurus
Jun 28, 2006 16:19 as a reply to  @ LordV's post |  #11
Brian V.
I could be wrong, but I thought you had to be wary of both apertures. I did a small, un-empiracle test with different apertures, and I think it agrees with me, but I could be wrong. See for yourself:
These are uncropped pictures taken with a reversed lens on the end of my Sigma at 300mm (extended to eliminate vignetting). They have the exact same settings except for the reversed lens changed aperture and the flash was intensified to compensate for loss of light.
I drew what looked to be the DOF on each one, and the first picture (taken with a reversed lens aperture of f/8 seems to have more DOF than the second one (taken at revesed lens aperture f/1.7). It could be paralax though, or some other error.
Body
: Canon 5D
1,310 views & 0 likes for this thread, 6 members have posted to it.
2046 guests, 130 members online
