Thread started 27 Jun 2006 (Tuesday) 06:01
Was wondering what curves are
dearis
Jun 27, 2006 06:01 |  #1
Hi there,
I was looking through a gallery and it showed 2 versions of a shot one with a small amount of pp, the other after the curves had been tweaked. Was wondering what that meant and if I had to shhot raw to use them (still have not been game to shoot raw)
Regards Darren
Canon 350d & other Canon things...
More of my photo's at http://DarrenDobbin.ph​otosite.com/ (external link)
lomond
Joined Apr 2004
Jun 27, 2006 06:07 |  #2
Ah the wonderful world of curves.
A simple S curve can work wonders but here's a quick tutorial.
http://www.luminous-landscape.com …ials/command_pr​imer.shtml (external link)
Cameron........My Images (external link)
nation
Joined Jun 2005
Jun 27, 2006 07:14 |  #3
And yes it can be used with JPEG images, with the usual image quality loss associated with the lossy JPEG files.
7D and lenses.
PIXI_666
Jun 27, 2006 07:57 |  #4
Curves is just improving the lighting situation on your shots you could have a very dark image - this is a good way for lightening them up without it looking too grey and badly edited. :)
Del
"Capturing, Creating & Preserving your memories"
Adelle Cousins Photography
www.adellecousins.com.​au (external link)
nfo@adellecousins.com.​au (external link)
tweatherred
Jun 27, 2006 11:16 |  #5
One way I have been taught to look at curves is that the levels tool is used to adjust the lightest and dakest points in an image, then use curves to adjust the midtones with more precision.
PacAce
Joined Feb 2003
Jun 27, 2006 12:24 as a reply to  @ tweatherred's post |  #6
Whatever you can do with Levels, you can do with Curves so there really isn't a need to use Levels first and then fine tune midtone with Curves. Since you're going to be using Curves anyway, you might as well do your black and white point adjustment with Curves, too, and forego the Levels adjustment.
...Leo
dearis
Jun 28, 2006 03:11 as a reply to  @ PacAce's post |  #7
Hi there,
thanks all, I have been using auto levels, and the links is a great somple one however I have been through every drop down box/menu in elements 4 and i cant find it anywhere, sugestions?
Regards Darren
DavidW
Jun 28, 2006 06:01 |  #8
I don't believe Elements 4 has Curves. There was a way found to get Curves in Elements 3 (which relied, I believe, on the support for Actions that is in Elements 3), but my understanding is that the same work-round doesn't work on Elements 4.
If you have Photoshop CS2, you have the ability to apply an overall curve in Adobe Camera Raw. Increasingly I'm applying my own custom curves in Camera Raw. Whilst Elements 4 uses the same Adobe Camera Raw 3 as Photoshop CS2, not all the options are available in Elements.
I can think of at least one plug-in that I think would add Curves to Elements (Curvemeister), but I'd argue that the cost would be better put towards an upgrade to a full version of Photoshop.
David
SuzyView
Jun 28, 2006 06:06 |  #9
I got this on the net that might help.
http://www.earthboundl​ight.com …shop-elements-curves.html (external link)
DavidW
Jun 28, 2006 09:52 |  #10
That's the site I was thinking of, Suzie. If you read it, the author says that he can't get things such as Curves working on Elements 4.
David
dearis
Jun 28, 2006 15:44 |  #11
hi there
will this work do you think, i mean is this what curves does ? http://free.pages.at/e​asyfilter/curves.html (external link)
regards Darren
DavidW
Jun 28, 2006 15:51 |  #12
If you're on Windows, I'd download that and give it a go - it looks not too dissimilar to Photoshop's own Curves command. The big difference is that you can't use a plug-in like that on an adjustment layer, but I'm not sure Elements supports adjustment layers anyway.
David
dearis
Jun 29, 2006 01:56 |  #13
G'day David,
got it and it works a real treat....I love it
Regards Darren
1,031 views & 0 likes for this thread, 8 members have posted to it.
2287 guests, 133 members online
