Thread started 28 Jun 2006 (Wednesday) 15:58
F5.6 and DOF question
dbiggs
Jun 28, 2006 15:58 |  #1
I was just talking to sombody ( friend taking photo corse at colage) that was telling me that opening you AV larger that f 5.6 does not affect your DOF at all because 5.6 is neutral. Is this true and if so why? I have been stopping my lenses down from 2.8 to like 3.5 thinking it would give me slightly sharper pic's even with the flash. I understand that the 2.8 would still give me a faster Tv and better AF but aI had no idea tha the DOF at 5.6 and 2.8 would be the same. Confused
EOS 20D
Canon 70-200 f4 L
Tanron 28-70 2.8 XR Di
Tokina 12-24mm f/4 AT-X 124AF Pro DX
Sigma APO 1.4 Teleconverter
Canon 18-55 kit lens
430 EX Speedlight
Manfrotto monopod/tripod
Lowepro AW 200 sling bag
standeford
Jun 28, 2006 16:09 |  #2
DOF certainly continues to decrease as you open up the apeture from 5.6 to 2.8, and on beyond that if your lens will do it.
It will also give you a faster Tv as larger apetures emit more light, thus the shutter doesn't need to stay open as long for proper exposure. With a given lens AF likely won't be affected by f2.8 versus f5.6, because your lens is operating at maximum apeture during focusing and only stops down when you take the shot.
Often lenses with larger maximum apetures will focus faster simply because they can emit more light, but there are many other factors affecting focusing speed.
Titus213
Jun 28, 2006 16:10 |  #3
Don't think so. Check this out:
http://www.dofmaster.c​om/dofjs.html (external link)
Dave
Perspiring photographer.
aparmley
Jun 28, 2006 16:16 |  #4
I'd tell your friend to drop that class and try a to get his money back. . . =) He's being mislead. Starting at say F1.4 - DOF [Is always dependent on distance the further you are from your subject the larger it is] is very narrow - stopping down to say F 4.0 makes the DOF larger etc etc - Stopping down means increasing Fnumbers 2.0 is stopped down for my 50 F1.4 - but its wide open for my 35 F2.0 - 5.6 is stopped down considerably for both of those lenses.
Its true that AF is better on 2.8 lenses or larger because the lens is used wide open to focus and stopped down to the set AV just as soon as you pull the trigger. . . so if you have a 2.8 lens and you are shooting in AV mode with the f stop set to F4.0 - the camera will focuse with the lens set at its widest aperture, 2.8 but when you take the image the lens stops down to F4.0.
Switched to Nikon . . . Thanks to all of you that made my sale a success! Enjoy your new gear!
stupot
Jun 28, 2006 16:26 |  #5
i wouldnt talk to him about photography... at least until he has finished his course:)
AF will not be affected by the aperture you select, the lens will focus at the widest aperture setting, regardless of the aperture you use. it stops down at the point of taking the photo - see for yourself, look into the lens when taking a pic stopped down.
Canon EOS 350D, Sigma 10-20 f4-5.6, 24-105 f4L IS, 70-200 f4L, 300 f4L IS, Kenko 1.4x pro300, 430EX, Apple Powerbook G4
Free filters for your flashgun!
stupot
Jun 28, 2006 16:27 |  #6
got beaten to it.. hehe
dontblink
Jun 28, 2006 16:33 |  #7
There is no neutral, the larger your aperature number (2.8,4, 5.6, 8, etc), which actually means the smaller your aperature the more DoF you have.
Canon 20D + grip
EF: 28mm f/1.8 & 50mm f/1.4
EF: 24-105mm f/4
L IS & 70-200mm f/2.8 L IS
EF-S:
10-22mm f/3.5-4.5 & 17-55mm f/2.8 IS
784 views & 0 likes for this thread, 6 members have posted to it.
2197 guests, 136 members online
