Thanks for the comments guys really appreciate the feedback.
MJ and Justin, I use Canon 1DMkII N bodies and three main Canon lenses, the 24-70 f/2.8, the 70-200 f/2.8 IS and the 500 f/4. I wouldnt mind adding something a little wider, but to this point just havent felt the real need to spend the money and do it, although at times I sit there and wish I had it.
I use two bodies and mainly just pick the two lenses I think I'll need for a particular corner or going to the pits or whatever. Rarely I'll also carry the third lens if I know the spot offers looks with all three or if I plan to hit the pits after coming back from a corner and wont have the opportunity to go to the media center and pick up the other lens. I keep the gear in a Think Tank Airport Security locked bag in the media center locked to a table or something, that way I have relatively easy access to it all since parking is not always convenient.
Gavin, thanks for the comment, that is saying a lot and I truly appreciate it.
Gary, thanks for the comments on the images and thanks for the suggestion as well. I'll have to play with that one a bit on the rotation. I didnt do that because I wanted to get as much of the sign in the backround as I could to give that tie in with the car, unfortunately I couldnt find the right angle to hit all of it. Rotating would require a slight crop and not sure how much would have to go. Also, its a weird image in the sense that you kind of want the sign to be level, but then the car is tilted in the opposite direction and levelling the sign will make the turn look banked a lot more. So its a great suggestion, I'll have to play a bit and see if there is an angle that works better.
Thanks again for all the comments and I'm always open to hear suggestions and ideas for making any of them better.
Off to Lime Rock.
