Thread started 30 Jun 2006 (Friday) 20:56
losing (sharpness) at full zoom
bromm
Jun 30, 2006 20:56 |  #1
I have been having a problem with getting subjects sharp at the 300mm mark of my tamron100-300, but it only seems to be a problem when the subject is not close ie. 60 feet or further away.Here is an example I shot today at about 80 feet.
This was shot using a monopod. Thanks for any help.Forgot to add this is a 100% crop
Trevor Wadman
Canon 40D/350D Canon 400L F/5.6, Canon 70-200L F/4 non IS. Tamron 100-300,Canon 18-55 Kit Lens. Canon 1.4 II Extender, Canon 430EX speedlight.
http://s41.photobucket​.com/albums/e286/bromm​/ (external link)
Transportithere
Jun 30, 2006 21:03 |  #2
I am experiencing the same. The sun light has been making a difference. Sometimes I think I am set for auto focus when the lens is not. I am learning that when I take more time with each capture the results are better. Manual focus works for crowded scenes.
POTN is a wonderful source of information.
POTN has taken me around the world.
crn3371
Jun 30, 2006 21:24 |  #3
Actually, for a 100% crop at 300mm with your lens, it really doesn't look that bad. All of the consumer tele zooms in that range are known to be soft at 300mm.
GyRob
Jul 01, 2006 06:34 as a reply to  @ crn3371's post |  #4
I agree here.
Rob.
"The LensMaster Gimbal"
bromm
Jul 01, 2006 14:45 as a reply to  @ GyRob's post |  #5
Thanks for the replies, so does that mean I should strive(other than obviously getting closer) to maybe only zoom to the mis 200mm's to keep the pics sharper??? thanks for the help!! Trevor
Trevor Wadman
SkipD
Joined Dec 2002
Jul 01, 2006 15:01 |  #6
Try using a good, as in very sturdy, tripod for another test at 300mm. I suspect that you will have better results. The longer the focal length one uses, the more problematic even small movement of the lens during the exposure becomes. While you used 1/400 second for the exposure, a bit more rigidity may be the solution.
Skip Douglas
bromm
Jul 01, 2006 17:38 as a reply to  @ SkipD's post |  #7
thanks Skip, I will give that a try. I was drooling over a manfrotto setup yesterday, might have to get on my wifes good side and go get one.Thanks again.
Trevor Wadman
943 views & 0 likes for this thread, 5 members have posted to it.
2284 guests, 133 members online
