Thread started 02 Jul 2006 (Sunday) 18:30
i'm stupid sometimes...
dan_c
Joined Jul 2004
Jul 02, 2006 18:30 |  #1
I went out the other day shooting. Beautiful day, great light, all the best conditions and I came home very pleased that I had some good shots. Then I realised that I've been all day long on iso 1600 from the previous night and of course all pics are very very noisy and not usable.
Do you ever do this kind of stupid mistakes?
EOS 30D
24-70 f2.8L
10-22mm f/3.5-4.5
70-200L f4
Speedlite 430EX
TooManyHobbies
Jul 02, 2006 18:32 |  #2
YOU ARE NOT THE FIRST. I had a once in a life time shooting session. A butterfly still pumping up its wings so it couldn't fly. I was able to put him where ever I wanted him to take shots for 20 minutes before he was able to fly. Only later did I realize I had it on 800 from the night before.
~ Jeff
Canon EOS-1DX & 1Ds MkIII, 20D(IR), G12, G9, G5, ... Gear List
JMM Photography ~ Discovering Art in Everyday Lifeexternal link | Model Mayhem #675060external link
liza
Jul 02, 2006 18:36 |  #3
Don't feel bad. I shot a low light wedding reception last night and forgot to change the ISO from 1600 when I shot at the Exotic Feline Rescue Center today. I could just kick myself!
Elizabeth
Blog
http://www.emc2foto.bl​ogspot.com/ (external link)
NickSim87
Sir Chimp-a-lot
Jul 02, 2006 18:37 |  #4
Blah....I've shot'em at 3200 before. I was thinking "Wow, it must be brighter then I think outside. 1/4000 sec at F/11!"
Gear List | Feedback
PIXI_666
Jul 02, 2006 19:43 |  #5
Yes, i do it a lot hahahaha but generally if i am shooting a wedding i am switched on, if im just shooting outside for myself - i make stupid mistakes like this!
"Capturing, Creating & Preserving your memories"
Adelle Cousins Photography
www.adellecousins.com.​au (external link)
nfo@adellecousins.com.​au (external link)
T.D.
Moderator
Gallery: 13 photos
Jul 02, 2006 19:53 |  #6
dan, I do that ALL the time! I get so frustrated at myself. I've vowed to make checking hte ISO the first thing I do every time I pick up my camera. Do I do it all the time? Heck no. I had some beautiful shots at a lake recently. I actually had to stop it way down to get what I wanted. Only later did I discover that I had it at iso 400! Argghhh!! I hate the noise at that level (unless you have no choice).
I literally missed conditions that were unbeatable. No people on the lake. No wind. Absolutely perfect...oh well, not much I can do about it now.
(My Gallery) (external link)
liza
Jul 02, 2006 19:57 |  #7
I wish Canon would introduce a custom function that would give the user an option to display the ISO on the screen. My Minolta A2 had that feature, and it was great.
Elizabeth
Blog
Hellashot
Joined Sep 2004
Jul 02, 2006 20:43 |  #8
Nope, never done that. I'm always aware of the lighting conditions and my shot settings, and adjusting the iso accordingly.
Which camera do you have that iso1600 would be unuseable? Only the Drebel and older would qualify for this. Remember that reducing the image size is a great way of noise reduction - which will show how it'll look when you print it. But if you need to crop tight and only view on a monitor at around 72dpi - then it might be fair.
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
TheSteveMadden
Jul 03, 2006 09:07 as a reply to  @ liza's post |  #9
Or a C.Fn to reset the camera to defined presets if the camera has been powered down for more than a few hours. THAT would have saved my bacon more than once.
Steve
Canon EOS 5D Mark II, 30D, XT, EF 24-70 f/2.8L, 50 f/1.4, 85 f/1.8, other EF lenses, 430EX, several 580EX II's, Pocket Wizard Plus II's, lighting supports and modifiers, etc etc etc
Website (external link)
saravrose
"I quit smoking dope"
Jul 03, 2006 09:20 |  #10
I used to do it constantly.. But, here's my trick.. when putting camera away I set it to green box.. when I go to use it again I have to adjust all my settings and therefore ISO gets set correctly....
Canon 30D BG_E2 Grip Rebel XT BG-E3 battery grip
Canon 50mm f1.8 Tamron 17-50 f2.8
Canon 70-200f4.0L 100-400L aka (Chuck)
a couple of bags and a lot of big ideas
"The shot is in my head before it's in front of my camera...."
Mike ­ R
Jul 03, 2006 09:45 |  #11
savarose - good idea, I usually take at least 1 shot before checking my ISO. I was trying to get into the habit of resetting it to 100 when I am done.
Mike R
www.mikerubinphoto.com (external link)
nation
Joined Jun 2005
Jul 03, 2006 10:14 as a reply to  @ Hellashot's post |  #12
Yeah never done it either. At least not for more than 3 or 4 shots after bumping up ISO if I temporarily moved into a low light situation. Not trying to sound conceited but something in the sky high shutter speed or closed apertures should have given it away.
Anyway one thing I always do when I first switch on the camera is press the info button and do a quick scan of my settings making sure to check ISO. I too wish ISO was in the viewfinder and also a CFn that would allow ISO to return to a preselected base line after taking a shot. That would be ideal for those situations where you move into a light situation for a one off shot.
7D and lenses.
kram
obvious its pointless
Jul 04, 2006 00:01 |  #13
My wrong ISO setting shots have come down hugely - first step when I switch on the camera is to check ISO :)
More than that, I try to play with manual settings and then you are forced to use all variables and while its tempting to leave ISO out of the equation, I find it helps atleast in not getting ISO 1600 shots in daylight :)
Canon 7D , Canon 6D, 100-400 L, 24-105 F4 L, 50 F1.4, Tokina 12-24 F4, Kenko Teleplus Pro DG 1.4X Extender
My Gallery (external link)
Thornfield
Joined Dec 2004
Jul 05, 2006 08:12 |  #14
Who's to say that noise = not useable. All depends on what you are shooting and what the end result is meant to be. I've done it and in the end ended up adding more noise to get the effect that made the shot sing.
Relationships are like photography, it has to click. :)
colleent
Jul 05, 2006 11:11 |  #15
Oh, yes, I've done it. I've done it on important shots. I'm trying to get in the habit of checking the ISO when I power up the camera and that gets ISO on my mind so that I'm always thinking about it when I'm shooting. I will often forget that important part of the exposure equation and get frustrated trying to get good shots.
My gear -- 30D, 300D, 24-105 f/4 IS L, 24-70 2.8 L, 70-200 2.8 IS L, 18-55 EF-S f/3.5-5.6, 50mm f/1.8 II, 85 f/1.8 420EX, 580 EX (I've been shopping :)
1,799 views & 0 likes for this thread, 17 members have posted to it.
2130 guests, 129 members online
