Thread started 03 Jul 2006 (Monday) 12:14
Compensating for Circular polarizer
Raindancer
Jul 03, 2006 12:14 |  #1
This is a general question about compensating using a light meter when I have a CP installed on a lens.
I'd like to use manual mode on my 20D and have got hold of a Sekonic L558. If I set for example I want to use F4 and the measured speed comes up as 125th sec, what would I set to to compensate for the CP?
Any advice would be welcome.
Thanks in advance
Rog
Roger
"All we have to decide is what to do with the time that is given to us." J.R.R. Tolkein
Canon EOS 5D
Canon EOS 20D
Canon EF 70 - 200mm F/2.8L USM
Canon EF 17 - 40mm F/4L USM
Canon EF 24 - 70mm F/2.8L USM
Canon EF-S 60mm f2.8 Macro USM
580EX Speedlite
crn3371
Jul 03, 2006 12:18 |  #2
I believe that a CP costs you 1-2 stops, so I guess you'd have to compensate accordingly. But, why not just use in-camera metering?
Raindancer
Jul 03, 2006 12:21 as a reply to  @ crn3371's post |  #3
Thanks for the info.......
I just want to see what difference it makes as the 20D does not allow true spot metering. :)
Rog
Roger
Canon EOS 5D
Canon EOS 20D
580EX Speedlite
SkipD
Joined Dec 2002
Jul 03, 2006 12:25 as a reply to  @ Raindancer's post |  #4
In order to discover the proper correction factor for your filter - and the conditions you are shooting in - meter the same scene botyh with the camera (NO filter) and the handheld meter. This is to verify that both are calibrated the same. Then, meter the same scene with the CP filter on the camera and using the camera's meter. The difference in exposure values found in the camera can then be transferred to readings made with the handheld meter. The difference, as stated above, should be in the 1 to 2 stop range.
Skip Douglas
PacAce
Joined Feb 2003
Jul 03, 2006 13:53 |  #5
Also note that the amount of compensation will vary (if you're looking for an exact number) depending on the degree of rotation of the polarizer and the position of the sun relative to the filter.
...Leo
Raindancer
Jul 04, 2006 06:25 as a reply to  @ PacAce's post |  #6
Thanks Skip, Leo, I'll be out this evening to give it a go...... won't get dark until after 9pm so lots of time to experiment.
Rog
Roger
Canon EOS 5D
Canon EOS 20D
580EX Speedlite
DocFrankenstein
Joined Apr 2004
Jul 06, 2006 10:05 |  #7
There's no single compensation value for CP.
Depending on what you shoot, you can take out from one to more than 4 stops of light from your scene.
National Sarcasm Society. Like we need your support.
harryb49
Jul 06, 2006 13:46 |  #8
The checking of exposures with a hand-held meter and the camera (with polarizing filter) will only work if you keep the filter turned to exactly the same angle.
Take care,
Harry
5D Mark III, 70-200is 2.8L. 16-35 2.8L II, Canon 24-70 2.8L. Canon 50 1.8. 580EX II
Dimitri_V
Jul 08, 2006 15:27 as a reply to  @ SkipD's post |  #9
Very good advice here from Skip.;)
My site (external link)http://www.earthsbeaut​ytours.com (external link)
Raindancer
Jul 09, 2006 07:20 as a reply to  @ Dimitri_V's post |  #10
Great advice Dimitri.......I've given it a go photographing my daughter in low light and found that the filter on my 60mm lens is 2 stops difference whilst on my 17 40 it's only 1 1/2.......
Rog
Roger
Canon EOS 5D
Canon EOS 20D
580EX Speedlite
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Jul 10, 2006 13:35 |  #11
I've read that with CPL vs non circular types, CPL's do not affect your light metering. However, in my personal experience, it is causing underexposure by less than one stop or so. So now I try a bit of +EV and check the histogram with better results.
Gallery: http://tomyi.smugmug.c​om/ (external link)
DavidW
Jul 10, 2006 17:10 |  #12
Circular polarisers don't mess up the metering or autofocus. Whilst most people talk about linear polarisers as affecting autofocus on many cameras, they can also mess up the built-in metering as well, leaving you with incorrect meter readings.
However, a circular polariser does have a filter factor - you do lose somewhere between a stop and two stops when using it.
David
1,217 views & 0 likes for this thread, 9 members have posted to it.
2123 guests, 129 members online
