does the histogram on the 20d show you when you have a correct exposure? I have been told that the peak needs to be in the middle. What if it is to the left or the right. Thanks
demarco36 Member 60 posts Joined Feb 2005 More info | Jul 03, 2006 18:53 | #1 does the histogram on the 20d show you when you have a correct exposure? I have been told that the peak needs to be in the middle. What if it is to the left or the right. Thanks
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | Jul 03, 2006 18:58 | #2 It doesn't matter where the peak is. What you don't want is a peak that is cut off at either the far left, or, far right.
arunchs Member 176 posts Joined Jun 2005 More info | Jul 04, 2006 00:38 | #3 Broadly speaking, brighter images will have peaks on the right and dark images to the left. But you may have some images, like that of snow where you need the peaks on the right. So peaks need not be in the middle though it is generally true. Arun
swapnali Senior Member 655 posts Likes: 1 Joined Mar 2006 Location: Tokyo More info | arunchs wrote: Broadly speaking, brighter images will have peaks on the right and dark images to the left. But you may have some images, like that of snow where you need the peaks on the right. So peaks need not be in the middle though it is generally true. What you should really look for is peaks at the extreme end of the histogram which is a definite case of loosing some information because you have let in too much light. or too less light Swapnali http://www.swapnali.com
Jesper Goldmember 2,742 posts Joined Oct 2003 Location: The Netherlands More info | Jul 04, 2006 04:52 | #5 Here is some information: Canon EOS 5D Mark III
| Latest registered member was a spammer, and banned as such! 2284 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
