Lately I've been reading alot about using a gray card to get proper exposure. How many of you use a gray card to get proper exposure readings? Is it beneficial with digital? What would be the best process of doing this with the best results?
paulcacciapaglia Member 187 posts Joined May 2006 Location: Houston, TX More info | Jul 04, 2006 08:38 | #1 Lately I've been reading alot about using a gray card to get proper exposure. How many of you use a gray card to get proper exposure readings? Is it beneficial with digital? What would be the best process of doing this with the best results? Paul Cacciapaglia
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jul 04, 2006 09:28 | #2 paul cacciapaglia wrote: How many of you use a gray card to get proper exposure readings? I seldom use a gray card for exposure readings these days because I have a handheld meter that can do incident readings. That is handier to use than a gray card. paul cacciapaglia wrote: Is it beneficial with digital? If you don't have a handheld meter (especially one that can do incident readings), the gray card can be indispensable at times - for either film or digital photos. If your subject has an average brightness range, a reflected meter (handheld or the one in your camera) will work just fine. If the subject is mostly dark or mostly bright, then the gray card (or incident meter) can be the tool you need to get a proper reading. Otherwise, the mostly dark or mostly bright subjects will come out looking like medium gray. paul cacciapaglia wrote: What would be the best process of doing this with the best results? Assuming that the only meter you have is the one in your camera, the process is something like this: Put the gray card in the same light as your subject, and at the same reflecting angle as your subject. Move in close so that the gray card is nearly filling the viewfinder (but not to the point of shading the light falling on the gray card) and take the exposure reading. Using the M (manual) exposure mode is likely to be the best way to do this so you can keep the exposure settings when you go back to the position to take the shot. Skip Douglas
Jul 04, 2006 15:58 | #3 thanks a million for your advice, Skip!! Paul Cacciapaglia
blue_max Goldmember 2,622 posts Joined Mar 2005 Location: London UK More info | A greycard is only a fixed, known value. It won't give you a better exposure than any other means. Checking the histogram will ensure you capture all the information and don't blow any highlights or block the shadows. .
Thornfield Senior Member 747 posts Likes: 1 Joined Dec 2004 Location: Christchurch New Zealand More info | Jul 05, 2006 07:57 | #5 If in a controlled environment where the light is constant then I might use the gray card. Relationships are like photography, it has to click.
| Latest registered member is ANebinger 1010 guests, 183 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
