Thread started 08 Jul 2006 (Saturday) 21:54
camera focus on wrong subject ???
picard
Jul 08, 2006 21:54 |  #1
why does the camera focus to a close subject when I actually want to focus on distant object. I have to continually adjust the focus. Is there a way to stop the camera from eratic focusing.
I have digital rebel XT with sigma 3.5f 70-200mm zoom lens.
Canon 1DM4,7D, Rebel XT
580 EX II, 430 EX II
Canon 70-200mm IS II L , Canon 85mm F1.2 L II, Canon macro 100mm F/2.8, 18-55mm kit
Sigma 18-200mm F/3.5-5.6, Sigma 10-22mm, Sigma 50mm F/1.4
Sigma 24-70mm F/2.8 EX DG HSM
MJP
Jul 08, 2006 22:10 |  #2
have you try to use a AF points manually?
:grin:MarkIIN,5D w/ grip,PS SD10
70-200mm f/2.8IS Canon 1.4X II|sigma 12-24mm
| EF85mm f/1.8|Ef 24-105mmL | 100mm macro| RS-80N3 | MinoltaAutometer|I9900|CS2|LR|CS3| Angle Finder
Manf 190MF4 tripod, 680 mono, 322RC2 Joystick Head |
580EXII,580EX,430EX,ST​-E2,CP-E3
www.pbase.com/marlonjp (external link)
crn3371
Jul 08, 2006 22:53 |  #3
Just manually select the focus point that you want. You also could just have center point as your default focus point and use the old focus, recompose,shoot method. Now, if you just shoot in Auto mode you can't select your focus points. You have to be in P, Av, or Tv.
ScottE
Joined Oct 2004
Jul 09, 2006 11:04 |  #4
There are two methods for autofocus to do what you want.
The first is to implant a transmitter in your brain that would communicate your wants to the camera. Usually this is accomplished by manual focus where your brain directs your hand to focus the camera where you want.
The second is to put sensors in the eyepiece of your camera that can determine what part of the frame your eye is looking at and then cause the camera to focus on that point. This feature is available on my EOS 3 film camera, but has not been included on any digital SLR yet. (I don't find it very useful anyway.)
For your digital SLR, you can set your camera to just use one AF point. I usually choose just the centre point, focus using that point and then recompose before taking the shot. If you have a fixed composition you may want to choose an off centre AF point that is over the point you want in focus.
Also, don't be a slave to autofocus. If it doesn't work immediately, focus manually instead of wasting time trying to get AF to work. That is the reason I will only buy Canon USM and Sigma HSM lenses that have full time manual focus override.
Wilt
Jul 09, 2006 11:12 |  #5
Sorry, but the 'do what I want' feature was not implemented in your camera. That will come in the future, when the camera has a wireless connection into our brains! The camera thinks that what is important in the photo is in the foreground, not the background...which is a reasonable assumption for it to make when your family is the foreground and Mt. St Helens is in the background. It has no way of knowing when someone else is in the foreground (not your family) and Mt. St Helens is really your object of interest.
As others have pointed out, you can make the CENTER your AF point; also you can set your Custom Function to put focusing on a button OTHER THAN the shutter button, so you can center on the real object of interest and prefocus on it with that button; then reframe the picture and press the shutter to shoot the picture without altering the focus.
Jamie ­ Holladay
Joined Nov 2005
Jul 09, 2006 15:53 as a reply to  @ Wilt's post |  #6
Picard do you know how to select a single AF point rather than all six? You may also want to try AI Servo (just a thought). I don't know what your are photographing.
SkipD
Joined Dec 2002
Jul 09, 2006 16:25 as a reply to  @ ScottE's post |  #7
EXCELLENT suggestion!
I feel that a lot of the folks using modern cameras are "stuck" on the automation - both autofocus and auto exposure systems. If there were an "auto-composition" feature, that would be used heavily as well I am sure.
Learning to take over control of the camera should be a goal for all photographers.
Skip Douglas
Wilt
Jul 09, 2006 16:51 as a reply to  @ SkipD's post |  #8
Yeah, just as purchasing an L lens makes everyone a good photographer! Sharper junk is still junk, you can merely see it better.
1,958 views & 0 likes for this thread, 7 members have posted to it.
2123 guests, 129 members online
