Thread started 09 Jul 2006 (Sunday) 05:01
Advice needed on using 430EX for macro
Vini
Jul 09, 2006 05:01 |  #1
I,m using a 430EX on my 350D. When i shoot macro i'm using manual mode on my camera with ISO at 100, shutter speed 200 and apeture f/16-f/22. The flash i set at 45 deg with a defuser and in ETTL.
The lens i use, is the Sigma, listed below.
My problem is, i have to wait about 30 sec to 1 min before the flash has recycled allowing me to take another picture.:mad:
Any suggestions and advice would be great.
One day i will purchase a decent macro lense..........for now, Partner, Children and Dogs won't allow me.:)
MY PHOTOS
http://www.flickr.com/​photos/viniryan/ (external link)
MY GEAR LIST
[350D] [KIT LENS] [17-40L:D ] [SIG 105 MACRO] [SIG 70-300] [KENKO EX TUBES] [430EX] [FLASH BRACKET] [BG-E3 BAT GRIP] [MANFROTTO MONO+TRIPOD] [AND LOADS OF BITS]
Omri ­ Alon
Joined Nov 2005
Jul 09, 2006 05:35 |  #2
Shoot ISO 200 and don't go over f/16 and try new batteries
Omri Alon | Flickr (external link)
Canon 6D
Samyang 14mm | 16-35L IS | Rokinon 24mm | 35mm IS | 85mm f/1.8 | 200mm f/2.8L | 430EXII
LordV
Jul 09, 2006 05:38 |  #3
How is the flash mounted ? Directly on the camera?
Brian V.
Macro Hints and tips
racketman
Gallery: 20 photos
Jul 09, 2006 06:40 |  #4
use NiMH rechargeable batteries such as Energizers2500 mAh.
Toby
Vini
Jul 09, 2006 09:39 as a reply to  @ LordV's post |  #5
Brian V.
Yes the flash is mounted onto the camera.
MY PHOTOS
MY GEAR LIST
LordV
Jul 09, 2006 11:16 as a reply to  @ Vini's post |  #6
Sounds like you do have duff batteries- as Racketman suggests use NiMH rechargeable batteries as these recharge the unit faster. I suspect from the way you are using the flash and the small aperture, you are probably using almost full power flash so are discharging the capacitors in the flash unit each time. Try bigger apertures say F11 and also try using the unit at normal angle with and without the wide angle diffuser deployed with no stofen on it.
In the longer term think about flash bracket and off camera flash cord to take the flash head nearer to the end of the lens.
Brian V.
Vini
Jul 10, 2006 09:35 as a reply to  @ LordV's post |  #7
Thank you very much for all your help, this forum and it's members are great.
I better get out and buy some NIMH rechargable batteries next weekend. Glad i'ts not a problem with the speedlite though, i didn't want to loose that, it was on backorder when i ordered it and took 4 weeks to deliver.:)
MY PHOTOS
MY GEAR LIST
1,484 views & 0 likes for this thread, 4 members have posted to it.
1823 guests, 112 members online
