Thread started 22 Oct 2003 (Wednesday) 11:45
1.4X II for the 100-400mm f4.5-5.6L?
murwille
Joined Jul 2003
Oct 22, 2003 11:45 |  #1
I recently purchased the 100-400mm L zoom for my 10D and am enjoying it very much. I appear to have a good sharp copy.
I am interested in buying the EF 1.4X II teleconverter for it. I already know about taping one of the contacts on the TC to maintain AF and have seen that it does slow down AF somewhat. My question is, for those of you who have used this combination, how does the image quality hold up? I realize I am asking a subjective question. Perhaps you could post some examples. I know I don't want a 2X TC because of image degradation.
Mark Urwiller
Phil ­ Hall
Joined May 2002
Oct 22, 2003 12:09 |  #2
You do not need to tape up the contacts with the 1.4x converter, you only need to do this with the 2x converter on the 100-400 mm lense. Focussing is a little slower. Image quality is better than enlarging an image 1.4x.
Phil Hall
Santa Ynez CA
1D;1Ds;1D MkII;16-35:28-135:70-200;100-400;600;550EX;580EX
chris ­ maddock
Joined Mar 2002
Oct 22, 2003 17:47 |  #3
You do need to tape them if using it with a 10D - that (like most EOS cameras) cops out and disables AF at f5.6, whilst a 1.4x on the 100-400 goes to f8.
Only the high end models (1D, 1DS, 1V and possibly the 3) can AF at f8, using the centre focussing point only.
KRs
Chris
Chris Maddock
Southampton, UK
http://www.dslr.co.uk (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 22, 2003 18:13 |  #4
Taping one contact?
I wish I knew which one.
I have taped three contacts as this was the info I had,. but my 500mm hates it when I do that,. so I would like to try just one if it will work.
Does anyone know of taping one cantact will work?
CDS' HOT LINKS
murwille
Joined Jul 2003
Oct 22, 2003 18:56 |  #5
CyberDyne,
Check out this link for the info you need.
http://www.fredmiranda​.com/TipsPage/ (external link)
Does anyone else have experience and perhaps photos taken with this combination?
Mark Urwiller
chris ­ maddock
Joined Mar 2002
Oct 23, 2003 07:35 |  #6
CyberDyneSystems wrote:
Taping one contact?
My 70-200/f4 doesn't work with a taped 1.4x, so I put the tape on the same contact at the back of the 100-400 - now both lenses work just fine with the 1.4x on my 10D, whilst the 70-200 works fine and the 100-400 reasonably on my old D30.
Obviously, those three contacts do different things with different lenses.
KRs
Chris
Chris Maddock
Southampton, UK
Ilker
Joined Oct 2003
Oct 23, 2003 08:01 |  #7
murwille wrote:
.... My question is, for those of you who have used this combination, how does the image quality hold up? I realize I am asking a subjective question. Perhaps you could post some examples.....
See http://www.photo.net …/photo.tcl?phot​o_id=25707 (external link)
Also see the following URL for 2x TC test
http://www.kums.be/dir​k/lenstest70-200/index.htm (external link)
Longwatcher
obsolete as of this post
Joined Sep 2002
Oct 23, 2003 09:06 |  #8
quick opinion,
The 1.4x will not noticeable affect quality in my opinion and although the 2x will. The level of detail you can get with the 2x is higher then if you took it without and then enlarged that portion of the image. Although if you took with 1.4x and then enlarged, that would be slightly better. I have however gotten some good shots (in very brightly lit conditions) with both attached at the same time, which in terms of detail were better then the enlargement of the 1.4x by itself.
Just thought you should know that the 2x can be worth it if you need the extra detail, but don't mind a slightly lower quality image.
Just my opinion,
[Trivia: detail is the ability to differentiate features in an image. Quality is how much I like it ;-)a]
"Save the model, Save the camera, The Photographer can be repaired"
www.longwatcher.com (external link)
1DsMkIII as primary camera with f2.8L zooms and the 85L
http://www.longwatcher​.com/photoequipment.ht​m (external link)
fredlord
Joined Jan 2003
Oct 25, 2003 21:03 |  #9
Tried this little tip today with my 1.4x TC II and 100-400L IS lens. Both items less than a year old on my D60.
This particular setup does autofocus. . . constantly! It hunts and dithers and clicks and whirs as long as I hold the shutter button down. I don't think I like it. It's nervewracking.
It wouldn't consistently hold at one focus point even though it was in one-shot mode. This may be because the D60 is less than satisfactory as a dim light focuser anyway. It didn't hurt anything to try and those of you with 10D bodies may find that it works because of the better autofocus capabilities. I hope so.
Good luck.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Oct 25, 2003 21:20 |  #10
Fred,. I have had the same expeirence with one of my Lenses,. this is why I was interested in this method involving taping ONE contact as opposed to THREE. It seemed possible that taping three was too much info the camera and the lens could no longer exchange.. but I now have to assume the the "One Contact" solution was just missinformation as no one seems to know which contact.
CDS' HOT LINKS
fredlord
Joined Jan 2003
Oct 26, 2003 20:15 |  #11
Well, there are only three so I guess we could try each one individually. I might try that tomorrow. I'm also working on multiframe-stitched panoramas and installing Mac OS X version 10.3 so I can't promise anything. This retirement thing is hell. Not enough time, too many things to do.
6,519 views & 0 likes for this thread, 7 members have posted to it.
1240 guests, 137 members online
