Thread started 16 Jul 2006 (Sunday) 00:29
Will a flash diffuser fix this?
dearis
Jul 16, 2006 00:29 |  #1
Hi there,
today I saw this spiral with a drop of water on the end of it (didn't see the spider initially) but I used the MT24-EX macro twin lite flash and as you can see it showed up in the drop of water, will a diffuser stop this?
I realise the shots not a great one (still learning trying to master the to and fro of focusing)
But any tips on what I did wrong would be great.
Regards Darren
Exif info. 1/200sec, F/5.6, 100mm macro lens ISO-100, Manual mode. Flash set to 2:1 -1/3 compensation.
Canon 350d & other Canon things...
More of my photo's at http://DarrenDobbin.ph​otosite.com/ (external link)
tim
Light Bringer
Jul 16, 2006 00:52 |  #2
A very large diffuser (like 1 meter high) will reduce it, but it's difficult to eliminate with on-camera flash.
dearis
Jul 16, 2006 01:04 |  #3
So adding a diffuser to the flash won't do enough?
tim
Light Bringer
Jul 16, 2006 02:05 |  #4
It might help a little, you'll get larger highlights that aren't quite so bright.
dearis
Jul 16, 2006 04:21 |  #5
No worries thanks tim......
Regards Darren
Thornfield
Joined Dec 2004
Jul 21, 2006 00:39 |  #6
Looks small enough to clone out with PS
Relationships are like photography, it has to click. :)
Curtis ­ N
Master Flasher
Jul 21, 2006 01:47 |  #7
Water has a very reflective surface. It will easily reflect any light source onto your image. Changing the size and/or position of the light source in this instance would merely change the size and/or position of the reflection.
I'm not aware of "diffusers" available for macro flash units. Are there any?
lostdoggy
King Duffus
Joined Aug 2004
Jul 21, 2006 02:02 |  #8
You could try tissue and rubberbands for a diffuser
drparker
Jul 21, 2006 10:07 as a reply to  @ Curtis N's post |  #9
Curtis is right, because the drop of water is a very curved reflective surface you'll get a reflection with just about anything. You could create a light box around it. You need a large enough diffused light that the reflection is evenly distributed across the drop and doesn't create a hot spot.
Drew
Join us in Chicago on April 22nd (Click here for more details)
5D, 85 f1.8, 24-70L[COLOR=black] f2.8, 70-200L f/4, 580ex, 430ex.
dearis
Jul 21, 2006 23:33 |  #10
I was able to do a bit with elements to minimise it.....looks a bit better
Sageg
Jul 21, 2006 23:51 |  #11
ARe you able to move this type of flash off camera? You could always have the flash to the side so that the angle of reflection was not visible from the camera??
Sarah
Eyes, hands, brains, legs
dearis
Jul 22, 2006 00:28 |  #12
Hi there,
Working on a bracket at the moment my brother in law is lazer cutting the plate for a bracket like this
http://cgi.ebay.com.au …ame=STRK%3AMEWA​%3AIT&rd=1 (external link)
But I would really like a bracket thats like a snake arm/arms to make them really flexible.
Regards Darren
1,072 views & 0 likes for this thread, 7 members have posted to it.
1956 guests, 128 members online
