Thread started 19 Jul 2006 (Wednesday) 04:33
Improving interior night shots, SD450
manning
Jul 19, 2006 04:33 |  #1
Some uneditted shots with an SD450, 200 ISO, no flash, auto white balance, 0 exp. I'd like some C&C to help boost sharpness & brightness, and reduce noise. Thanks.
ibdb
TD's worst nightmare!
Location: Puyallup -- Don't worry. Nobody else can pronounce it either.
Jul 20, 2006 01:15 as a reply to  @ post 1742407 |  #2
Sharpness -- did you use a tripod? The exposures in each of these shots were long enough that you really need a very solid platform to avoid any sort of motion blur affecting your images. If it was on a tripod, try using the self timer to eliminate pressing the shutter from contributing to motion problems.
Noise -- partially a limitation of the camera and ISO. I'm not familiar with your camera, so I can't tell you a whole lot more. Maybe look for suggestions in the P&S forums here? Improper exposures will increase noise, and these were probably a little difficult to get right.
Brightness -- in the light you apparently had available, I'm not sure how much more brightness could be expected. You might be able to get brighter results with more post processing (Photoshop is your friend), but if you brighten too much, you'll risk increasing noise.
-David
"David raises a good point. . ." -- CDS
"Once again, David Raises a good point! :lol:" The Wise and Powerful CDS
Gear List | Proof I Use The Gear In My Gear List (not necessarily proof I use it well) (external link)
850 views & 0 likes for this thread, 2 members have posted to it.
2499 guests, 98 members online
