Thread started 19 Jul 2006 (Wednesday) 19:51
blowing up an image for printing
ScruffyJohn
Jul 19, 2006 19:51 |  #1
is there a way one can tell what the max size an image can be blown up for printing? Meaning I have an image that looks fine for 8x10, but when I printed it at 11x14, it really looked bad... not as crisp as the 8x10.
or is this all trial & error?
John
Canon 30D/300D
24-105L, 10-22, 100mm macro
Kit lens (18-55), 28-135, 100-300
SWPhotoImaging
Joined Nov 2003
Jul 19, 2006 22:11 |  #2
any 4Mp image should go to 8x10 just fine. 6Mp will go much larger if it starts out clear and clean. I have gone to 20x30 with 6Mp 10D images many times.
The current 8Mp Canons will do that easily.
SWPhoto-Imaging
chris ­ clements
Joined Mar 2004
Jul 20, 2006 09:44 |  #3
You'll be ok as long as you've got between 200~300 pixels per inch of print.
So, in your example, an image with 2000 pixels on the long side should give a good 10" long print, but the individual pixels may start to show at 14", when your density will have dropped to ~140 ppi.
Any current EOS will be OK for 14" at full frame. If not, look to your technique!
ScruffyJohn
Jul 20, 2006 12:33 |  #4
ok, thanks
some of the images I was thinking of printing are
https://photography-on-the.net/forum/showthre​ad.php?t=194078
John
Canon 30D/300D
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jul 21, 2006 06:55 |  #5
You should be able to get a sharp 12X18" image from the 300D. I did it many times. Of course, if you're shooting medium jpegs, you should probably stick to the 8X10"s?
And... RAW rocks!
SonyaL
Jul 24, 2006 22:05 |  #6
Some of the cheaper labs that I dont use for printing you can upload to them and it will tell you the max size the pic would look good at.
I think one was target.com
Sonya
1,039 views & 0 likes for this thread, 5 members have posted to it.
1686 guests, 131 members online
