Thread started 22 Jul 2006 (Saturday) 15:41
problem with lens, advice pls.
seanm
Gallery: 25 photos
Jul 22, 2006 15:41 |  #1
Hi everyone, I have a 700-200 f4L and I am constantly getting this grey smudge on images, like so :
I know this can be post processed easily, but I would like to know how to fix it and what is causing it, as I have cleaned both the front and rear glass, possible on some glass inside?
Thanks in advance.
Sean
C&C welcome.
kevin_c
Jul 22, 2006 15:44 |  #2
Looks like dust/dirt on the sensor to me - do you have any other lenses to use?
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
BearLeeAlive
All butt cheeks and string.
Jul 22, 2006 15:44 |  #3
That is most likely a dust spot on you sensor, does it show up with any of your other lenses?
-JIM-
BearLeeAlive
Jul 22, 2006 15:45 |  #4
LOL, Kevin, you are a wee bit quicker on the draw I see.
-JIM-
seanm
Gallery: 25 photos
Jul 22, 2006 15:46 |  #5
Unfortunately no, if it is on the sensor do I need to send it away?
Sean
C&C welcome.
kevin_c
Jul 22, 2006 15:47 as a reply to  @ BearLeeAlive's post |  #6
I said that :-)
-- K e v i n --
Roy ­ C
Jul 22, 2006 15:53 |  #7
Dust spots like this can be cloned out in seconds in your image editor. I have several on my sensor but they only show on sky shot of say f11 and over.
TOP BIRD SHOTS (external link)
MY PHOTOSTREAM (external link)
500px gallery (external link)
BearLeeAlive
Jul 22, 2006 15:58 |  #8
I would try a shot of the sky stopped right down to your smallest aperture on a couple lenses and see if it will then show up. It so, it is dust on the sensor and can be easily cleaned. It it still only shows up on the 70-200 it must be something with the lens. I have had dust in a lens though and it really does not show at all, at least it never in any of the pics I took with it even after searching hard for something.
-JIM-
Jon
Joined Jun 2004
Jul 22, 2006 16:01 |  #9
If everyone's finished gloating/moaning over who said what first :{)#
No, you don't need to send it away. If you're in one of the Creative Modes, there's a "Clean Sensor" option on your menu. This will hold the mirror and shutter open until you power down. During that time you'll be able to use a Rocket Blower or a Copperhill/Eclipse swab to clean off the spot. There are many, many threads on how to clean your sensor; I won't repeat them. Suffice it to say that you're seeing the spot with the 70-200 because you're shooting aircraft with it - this means shooting at the sky, which typically results in a small aperture. You'll see spots much more readily with small apertures, but the lens is irrelevant. Put your kit, or other, lens on, point the camera at a light surface, dial in some +EC and shoot in Av at f/16 and you'll see the spots too.
Jon
Cocker Spaniels
kevin_c
Jul 22, 2006 16:04 |  #10
seanm - you may find this thread useful regarding sensor cleaning:
https://photography-on-the.net/forum/showthre​ad.php?t=102929
-- K e v i n --
2,111 views & 0 likes for this thread, 5 members have posted to it.
1047 guests, 103 members online
