Thread started 23 Jul 2006 (Sunday) 19:27
A620 help needed please
Storm2
Jul 23, 2006 19:27 |  #1
When I d/l my Images from my A620 which method is the best to use & why ?
1-D/l images using the Camera
2- D/l images using the Computer
By Default in either method the images are saved into subfolders according to their Shooting dates. How can I alter this to show the Downloading date ?
I have to use a Hub , because I have only 2 USB ports at the back of the Computer. Realize this makes the process slower but is there any thing else bad envolved ?
Thanks .:) Storm2
Stefan ­ A
"The D is supposed to be where the S is!"
Gallery: 11 photos
Jul 23, 2006 20:30 |  #2
I put my card in a reader (or just connect the camera directly) and then click my computer and then click the camera. Works for me.
Stefan
80D, Canon 17-55mm f/2.8, Canon 18-135mm f/3.5-5.6, Canon 50mm f/1.4, Canon 70-200mm F/4L,Tokina 11-16 f/2.8, Canon 100-400 f/4.5-5.6, Kenko 1.4 TC, Canon 580 exII Speedlite, ebay wireless trigger, Genesis 3 light kit
santwarg.zenfolio.com (external link)
hwyhobo
Jul 23, 2006 22:31 |  #3
Shouldn't be any difference, at least I didn't notice.
I am not sure there is such an option, or I haven't found it. Since I always move the files afterwards to other folders by topics and/or location, it does not matter to me. BTW, if you have Windows XP, you don't need to use the Canon utilities to download images. You can just copy them over from the camera to your computer and put them directly into any folder you like.
There is of course also a possibility of using a card reader, but I damaged a couple of cards that way in the past and stick with USB now.
I have to use a Hub , because I have only 2 USB ports at the back of the Computer. Realize this makes the process slower but is there any thing else bad envolved?
There should not be any effects. Since it is a digital process, it either works or it doesn't. No in-betweens. ;)
Jon
Joined Jun 2004
Jul 24, 2006 10:31 |  #4
If you use a card reader you can use Windows Explorer to create folders and copy the files. You don't have to use Canon's software . I personally use Downloader Pro from Breexze Systems as it lets me attach IPTC information to the files (captions, topics/categories, copyright information) to the photos. That's directly to the photos - it's embedded in the JPEGs or RAWs.
Mere use of a USB hub shouldn't reduce USB data transfer speeds. If you're not using USB 1.1 devices in it, it should provide you with the full 480 Mbps potential, which neither your camera nor your cards in a reader will be able to keep up with. However the card reader is going to be much faster than a direct camera-computer transfer, especially with a large number of photos.
I always use a card reader. It's faster than d/ling direct from the camera; I can review the pictures on the card while I'm transferring them, and I don't run down the camera battery while I'm copying files (which can have a negative effect on your memory card).
Jon
Cocker Spaniels
larryf1952
Jul 24, 2006 16:33 as a reply to  @ Jon's post |  #5
I'm running XP, and I use a SanDisk card reader connected through a 4 port USB 2.0 hub, so I don't have to always be plugging/unplugging my cameras. I store my photos in folders on USB flash drives, and have not installed Canon's software on my PC. If I want a certain photo or group of photos, I just pull the appropriate flash drive and go from there. So far, so good!
Storm2
Jul 25, 2006 00:09 as a reply to  @ larryf1952's post |  #6
Thanks for all your helpfull sugestions. According to MS Support I should be able to connect to my XP computer with USB ,tried it but guess I will have to uninstall the Canon software first, because thats what shows up. I will look into getting a Card Reader as it seems the best way to go maybe .
hwyhobo how did you manage to damage the cards in your Reader?
I hate putting those small USB connections together:(
Really like my A620 & my daughter was very happy to get my old A70.:D
Storm2
hwyhobo
Jul 25, 2006 01:10 as a reply to  @ Storm2's post |  #7
I am clumsy with delicate things. I must have bent them or put them at less than perfect angle, and sure as day after a while first one then another developed intermittent contact problems.
I hate putting those small USB connections together :(
See, and I never managed to screw up that one. Not yet. I guess USB connectors must be more clumsy-proof. :lol:
1,452 views & 0 likes for this thread, 5 members have posted to it.
1620 guests, 100 members online
