Thread started 24 Jul 2006 (Monday) 16:56
Why can lenses be set beyond infinity?
Raymate
Jul 24, 2006 16:56 |  #1
Does it have a use?
Canon: EOS 5DmkII • 50D • 40D • 350D • 100 f2.8L IS Macro • 70-200 f4L • 24-105 f4L IS • 17-40 f4L • 50 f1.4 • 60 f2.8 Macro • 85 f1.8 • 430EX • 580EX II • ST-E2
Sigma: 10-20 f4-5.6 EX DC HSM • 30 f1.4 EX DC HSM • 17-50 f2.8 EX • 24-70 f2.8 EX DG MACRO
Apple: CS3, Aperture & iPhoto. Various Manfrotto, Portaflash, Battery Grips, SanDisk & Lowepro
alamy: my stock photography (external link)
fivefish
Jul 24, 2006 17:02 |  #2
You know what they say... "To infinity, and beyond!"
I think it allows you to look into the future, some time warp thingy. :)
Save money! Check out my DIY projects (external link)!
Canon EOS 30D, Canon Digital Rebel
Canon 10-22mm EFS, 70-200mm f4L, 24-105 f4L IS
Canon 50mm f1.8 EF, Canon 75-300mm EF lens
Sigma 150mm Macro, Canon 380EX Flash
DIY High-Speed Sound-activated Flash Trigger and Nikon SB-26 Flash
Raymate
Jul 24, 2006 17:04 as a reply to  @ fivefish's post |  #3
Think your right, as i typed the post i turned the lens and saw your comment before you posted it :)
Big ­ WIll
"Slight breach of etiquette"
Jul 24, 2006 17:14 |  #4
Just incase you see something a little bit further than infinity! obviously!
Computers blur the boundaries... We are being released from the suddenness of photography, the suddenness of the shutterhttp://www.photography​-on-the.net …p?p=1606920&pos​tcount=132
GyRob
Jul 24, 2006 17:22 |  #5
Take no notice of the comments IT'S for further than infinity shots of cause ;)
Rob.
"The LensMaster Gimbal"
Mr. ­ Clean
Jul 24, 2006 17:24 |  #6
I read something about DSLR's and focusing beyond the infinity mark...I don't remember what it was, something like focusing beyond the hyperfocal length and not necessarily beyond infinity of course
Mike
some shots @ Zenfolio (external link)
Doom1701e
Joined May 2004
Jul 24, 2006 17:26 |  #7
I've seen into alternate universes with my lenses set to beyond infinity. :-P
www.firemaplephotograp​hy.com (external link)
flyingmachine
Jul 24, 2006 17:29 as a reply to  @ Mr. Clean's post |  #8
I asked a similar question before, basically it allows the cameras autofocus system to focus at infinity. It needs to move past the optimal focus point then return to it. With the kit lens in bad liighting conditions it's pretty obvious.
20D, T2i, 50 1.8, 70-200 F4, 17-40 F4
430ez
35mm Minolta w/ 24 f2.8 50 f1.7 135f2.5
SkipD
Joined Dec 2002
Jul 24, 2006 17:35 |  #9
The slight overtravel also allows for mechanical expansion and contraction of the lens focussing components without affecting the ability to adjust the focus at infinity, both automatically and manually.
Skip Douglas
Raymate
Jul 24, 2006 17:36 as a reply to  @ flyingmachine's post |  #10
Thank You... now you say that it makes sense if the lens hunts it needs to go maybe go past it and then back again to lock
Raymate
Jul 24, 2006 17:37 as a reply to  @ SkipD's post |  #11
This makes even more sense :)
FlashZebra
This space available
Jul 24, 2006 17:49 |  #12
Skip D's explanation is the vital one that has been in play, long before auto focus lenses were ever available.
As lenses get more massive and long (more potential to expand or contract due to temperatures), the need to have a bit of "extra infinity" increases.
A refractor 500 or 600mm lens at 30 degrees F is meaningfully shorter (in an optical sense) than the same lens at 105 degrees F.
But, the lens must focus at infinity in both conditions. This is the reason for the required infinity slop.
Enjoy! Lon
steved110
Jul 24, 2006 17:57 as a reply to  @ FlashZebra's post |  #13
All lenses can focus slightly beyond infinity, even the ancient manual everything lenses. the reason for this is two-fold - firstly depending on ambient temperature, things expand and contract, slightly, and this could affect focus if your lens came to a sudden halt at some arbitrary point.
Secondly, when focusing, the AF camera needs to see a phase contrast, and quite frankly so does the human eye - if you have ever manual focused or used a microscope you will realise that you always overshoot the focus then wind back and forth a few times to assess the focus - voila! you need to be able to focus beyond infinity.
Besides, it has a nice Zen thing about it.....
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
fivefish
Jul 24, 2006 18:02 |  #14
It's kinda like buying a guitar amp. You want to buy an amp that can go to 11.
I mean, why buy an amp that can only do 10 on the volume knob?
What do you do when you're playing in a concert and the drummer won't quiet down? And your amp can only go max at 10? You're doomed.
You need to kick it up a notch. Need to turn that dial to 11!
JCR
dubiously affectionate
Jul 24, 2006 18:04 |  #15
someones been watching too much spinal tap :D
There are 10 types of people that understand binary, those that can and those that can't.
3,275 views & 0 likes for this thread
Latest registered member is beniciovin
673 guests, 270 members online
