Thread started 31 Jul 2006 (Monday) 10:50
Rebel XT problem.....HELP
Gerdav43
Joined Sep 2003
Jul 31, 2006 10:50 |  #1
New symptom just appeared with my camera. When using the main dial it will only function in one direction. Example........In AV mode. If I turn the main dial to clockwise, aperature will change from say 2.8 and go up. If I turn main dial counterclockwise, aperature setting will not go back down but will proceed up. What the heck is going on ?????
This symptom is true in all aspects of use whether it is navigating menus or in other modes such as TV or P mode. I can only increase settings no matter what direction I turn the main dial. I have tried taking out the battery and re-inserting, what other things should I do? Did I accidently change a setting? I tried using my Opteka battery grip main dial and had the same symptom. Will re-installing the firmware rectify the problem?
Canon 60D
Canon 70-200 F4 L + Sigma 1.4 T-con
Canon 50mm 1.8
Canon Speedlite 580EX/Canon Speedlite 420EX
Jon
Joined Jun 2004
Jul 31, 2006 10:58 |  #2
Have you tried removing both the main battery and the button cell and letting it sit? I doubt that re-installing the firmware will solve this.
Jon
Cocker Spaniels
Jaime
Jul 31, 2006 11:41 |  #3
I would also try to take out and reseat the lens in the event that either it is not making full contact or its not fitted properly.
"My eyes see but a minute reflection of what my soul
longs to capture through the sensual art of photography."
Jaime E. Pagán
https://photography-on-the.net …php?p=6253713#p​ost6253713
Gerdav43
Joined Sep 2003
Jul 31, 2006 12:12 as a reply to  @ Jaime's post |  #4
I've tried both these solutions so far.
Thanks Anyway.
Anyone else have a similar problem?
Canon 60D
Canon 50mm 1.8
05Xrunner
Goldmember, Flipflopper.
Gallery: 52 photos
Jul 31, 2006 12:18 as a reply to  @ Gerdav43's post |  #5
are u using a lens that has a larger ap on the tele and zoomed it out some by accident like the kit lens
My gear
Fuji X-T2, Fringer Pro EF-X, 14 f2.8, 18-55 2.8-4 OIS, 35 f2, 50 f2, 90 f2, 55-200 3.5-4.8 OIS, Tamron 150-600 G2 VC
Sony RX100 II
mysubaruimp
Jul 31, 2006 12:25 as a reply to  @ 05Xrunner's post |  #6
This happened to me once. I found it was a problem with the grip. Take the grip off the camera and try it.
Camera
Lenses
Flash
Gerdav43
Joined Sep 2003
Jul 31, 2006 12:31 as a reply to  @ mysubaruimp's post |  #7
I have tried without the grip......X05runner, Don't know what you mean. I was using the kit lens when this happened and then switched to my Tamron Lens, the 28-75.
This phenomenon also occurs without a lens on the camera. If you scroll through menus you can only travel in one direction no matter what direction you turn the dial. Sounds to me like the dial went bad but will wait to send it in and see anyone else has a suggestion.
Canon 60D
Canon 50mm 1.8
Jon
Joined Jun 2004
Jul 31, 2006 12:42 |  #8
If it were only happening with the camera's Main Dial, I'd agree that it sounded like a problem there; since you say it's also happening with the Main Dial on the grip, in exactly the same way, I'd suspect the problem to be elsewhere. As a last resort prior to sending it in, you might try rre-flashing the firmware, but I don't hink that will really help. It might even be difficult to manage, trying to navigate one-way through the process.
Jon
Cocker Spaniels
Gerdav43
Joined Sep 2003
Aug 01, 2006 13:22 as a reply to  @ Jon's post |  #9
No answers here so I sent it in to Canon. If I get an answer I will post the solution.
Canon 60D
Canon 50mm 1.8
tbrasington
Aug 01, 2006 13:25 |  #10
I had the exact same issue the other week with my XT. No luck with anything. Different lenses, batteries etc. However in the morning it was fine again.
7D | Speedlite 430 EX | 17-35mm f/2.8 L| 24-70mm f/2.8 L | Sigma 30mm f/1.4 | Flickr (external link)
Gerdav43
Joined Sep 2003
Aug 15, 2006 22:26 |  #11
Hope not to scare everyone here. But I just received my camera back from Canon. They performed the following repairs but did not indicate what the problem was exactly. They replaced the top cover assembly which is the area around the main dial (they replaced the main dial switch) and the shutter button. They cleaned the sensor (unrelated standard warranty work when you send a camera in), they updated the firmware, probably becuase they also replaced the Printed Circuit Board (I was up to date on the firmware prior to sending it in). At least I got all this through warranty but why would this fail? Is this a heat related failure (maybe I left it in the car one hot day but I will deny deny deny, or a fault in the circuit board that permits the type of issue. I ask the second part of this question because others have had this issue, but were fortunately able to rectify the problem through various means. I found so many answers around the web and there was not one clear answer. Mine seemed fatal but others are able to remove a battery and all is okay?
Good luck to all. Sorry I raised more questions than answers.
Canon 60D
Canon 50mm 1.8
StewartR
"your nose is too big"
Aug 16, 2006 04:42 as a reply to  @ Gerdav43's post |  #12
It seems you were just unlucky. The fact that nobody else could help, or had seem anything similar, suggests it was an isolated fault rather than an endemic one.
www.LensesForHire.co.u​k (external link) - complete with matching POTN discussion thread
Photos: Cats (external link) | London by day (external link) | London by night (external link) I My POTN photo sharing threads (external link) | Official "Where Am I Now?" archive (external link)
Gear: 350D | Sigma 18-200mm | EF-S 10-22mm | EF 50mm f/1.4
Gerdav43
Joined Sep 2003
Aug 16, 2006 09:15 as a reply to  @ StewartR's post |  #13
Yes, but the symptom has been reported widely, typically by users of the Rebel Xt and a battery grip (Canon or Opteka does not matter).
Canon 60D
Canon 50mm 1.8
Ocelot
Aug 16, 2006 16:01 |  #14
hmmm, interesting post, lucky me, i don't use battery grip....
Rebel XT
18-55mm
storeman
Aug 16, 2006 16:29 |  #15
Like any manufactured goods, a small percentage will either be faulty immediately after production or fail within a short time of first being used.
Although you state this fault is widely reported, there are a far greater number of xt/350D users who haven't reported this problem because they haven't suffered from it.
You are one of those who unfortunately got a camera thet was in that minority that failed but Canon honoured their warranty promise and you are again in possesion of a working camera. Inconvenient for the time you were without maybe but it worked out in the end. Glad it was sorted out quickly.
My Gear List.
2,665 views & 0 likes for this thread, 10 members have posted to it.
566 guests, 120 members online
