Thread started 31 Jul 2006 (Monday) 13:49
How Can I Photograph Bathrooms With Mirrors?
nitekatt2006
Jul 31, 2006 13:49 |  #1
Hey shooters. I am taking a crack at photographing a client's house which has been going ok until I started to set up lighting and camera to shoot the bathrooms. I don't know how to get good images dealing with the reflections in the mirrors. How do the pros handle this challenge? Strobe or no flash recommended? So far, I just see myself in the mirror holding the camera. Also the glass shower windows has got me scratching my head on what to do about that. I know it can be done, I read Architectural Digest, but there has to be a workaround. Is it all done in Photoshop to mask it out? Please help, as I have to start this Wed and she is expecting a solution. Thanks to everyone for your expertise. katt
Canon 10D and 30D. Tokina 80-200mm Pro 2.8 zoom, Sigma 50mm 2.8 macro, Sigma 10-20mm f4-5.6, Canon 28-135mm f3.5-5.6 IS, 2 AB 800
Lightstream
Yoda
Joined Feb 2006
Aug 01, 2006 05:13 |  #2
I'm no expert but recently I was taking a few pictures around my own place, and yup.. there are mirrors and computer monitors that reflect flash light back at the source. I dealt with them by using a bare flash (white card and Stofen Omnibounce throw light forward which reflects off the surfaces) pointed 90 degrees straight up at the ceiling so it makes it look as the light is coming from above, as is expected in houses. The ceiling is white, which is to my advantage. Managed to get the results I wanted. I stayed out of the reflections of the mirrors.
peterdoomen
Location: Lier, Flanders (northern, flemish speaking part of Belgium)
Aug 01, 2006 09:07 |  #3
Fast wide lens, like the Tamron 17-35 does the job at f/2.8 (adjust ISO if needed).
Add a few light spots (out of frame, of course) if needed.
P.
Canon EOS 20D | Canon 70-200 f2.8L IS + Hoya UV Filter | Canon Extender 1.4x | Canon 50 f/1.8 | Canon 85 f/1.2L mk II | Tamron 17-35 f/2.8-f/4| Tamron 28-75 f/2.8 | Tokina 100 f/2.8 macro | Kenko extension tubes | Canon Speedlite 420 EX & Sto-fen Omnibounce| 80GB Flashtrax | Manfrotto Tripod 190 pro B & Joystick 322RC2 | Lowepro Micro Trekker 200
PDFs: Make money with ShutterStock (external link) - Make your own Tabletop Studio (external link)- Glass Buying Guide (external link)
My ShutterStock Gallery (external link)
elTwitcho
frustrating as ....
Aug 01, 2006 09:49 |  #4
Tripod and a long exposure to preserve the original lighting in the room.
Tilt shift lense so you can set the camera up to the side without any perspective distortion. You see this in most interior decorating magazines where the mirror looks like it has been shot head on, but the reflection shows stuff off to the side.
Rich
Some of my recent projects
Portraits from 2007 (external link)
Urban Gallery (external link)
Where Toronto Was Built (external link)
People and such (external link)
Rhinotherunt
Looking for a Rock
Aug 01, 2006 10:26 |  #5
Ditto what Rich said...
Ryan McGill
My Gearhttps://photography-on-the.net/forum/showthre​ad.php?t=592450
E3_Photo_Studio
Aug 01, 2006 10:31 |  #6
You can use a flash/strobe, just use the ceiling or a wall too bounce the light off of and make sure that you don't have the light too close to a reflective surface (ie mirror or glass). I take mirror shots when doing weddings, and I just bounce the light off of the ceiling to get a more balanced lighting look, and I've never had a problem.
If you're going to use a time delay and use the regular tungsten lighting in the bathroom, you'll need to use a filter so that the images don't turn yellow/brown from the lighting. Just something to keep in mind.
Erika
http://www.e3photograp​hystudio.com/ (external link)Website (external link) | Facebook (external link)
corinto
Aug 01, 2006 10:52 as a reply to  @ E3_Photo_Studio's post |  #7
E3_Photo_Studio wrote:
... you'll need to use a filter so that the images don't turn yellow/brown from the lighting.
If digital, it is probably better to do a custom WB at the very start of the shooting. Watch out for light change, though. Light bulbs do have a different color cast depending on brand, age, voltage variation. If fluorescent, you should keep a lower shutter speed to capture over 1 cycle (below 1/50 sec).
Julio.
http:// …
nitekatt2006
Aug 01, 2006 12:25 |  #8
Wow! Guys, thanks so much for your advice and input. Looks like bathrooms are tough to do for almost everyone who faces the challenge. Also with the 1.6 crop factor on my 10D, I am looking at a super wide angle zoom that starts with a 15-17mm-40, etc. looking at Sigmas, anyone using Sigma ultra wide zooms for interiors? Thanks katt
Lightstream
Yoda
Joined Feb 2006
Aug 01, 2006 19:37 |  #9
For the 10D, a 17-40 (for example) would be considered just 'wide', not ULTRA wide. It roughly converts to 28-64mm, which in classical 35mm photography is considered just wide. Still, it may be enough for your needs.
Anything below that, say a 10-22 (for example, I know you can't use the EF-S version), would convert to 16-35mm. 16mm equivalent would be considered ultrawide.
I did the interior shoot with an ultrawide, 17-40 on a 5D. No crop factor so I get a true 17mm at the wide end and boy did I need it.
Maybe try a Sigma 10-22, it would give you a similar FOV and it mounts on a 10D. All the best with your shoot!
kram
obvious its pointless
Aug 01, 2006 22:40 as a reply to  @ elTwitcho's post |  #10
I prefer this - but many houses still end up dark / unnatural when shot with a tripod for a long exposure.
I have had limited success with an upward facing flash - it tends to not light up the room evenly and ends up even more unnatural :(
Canon 7D , Canon 6D, 100-400 L, 24-105 F4 L, 50 F1.4, Tokina 12-24 F4, Kenko Teleplus Pro DG 1.4X Extender
My Gallery (external link)
nitekatt2006
Aug 02, 2006 00:54 |  #11
Guys, we just ordered the Sigma 10-20mm zoom for the Canon 10D. I'm also upgrading to the Canon 30D and possibly 5D, so the lens should work ok with the new cameras as well. I read a lot of recommendations on this lens in the lens forum on the board here and most shooters seemed real pleased with it's sharpness and quality. With the 1.6 crop factor, my 24-200mm just ain't cuttin' it. Hopefully the 10mm will be able to get more real estate in the frame without a lot of distortion. I'll keep you posted. katt
Becca
Lady in Red
Gallery: 25 photos
Aug 02, 2006 06:00 |  #12
I used to have to photograph bath vignettes for a home center to be used in setting up new stores. We had this spray stuff that you sprayed on the mirror that dulled the surface so you didn't get reflections. It was a pain to have to clean all the mirrors when we were done, but it did make it easier to photograph. They were taken in-store with all those fluorescent lights and merchandise across the aisle so it was really crappy shooting conditions.
Becca
"The world is a book, and those who do not travel read only one page." ~ Saint Augustine
Raphael ­ Emond
Aug 03, 2006 03:20 |  #13
If you think about the 5D in the future, the Siggy 12-24 is the ONLY lens in this range
compatible with FF at 12mm....
Canon Rebel XT, BG-E3, Sigma 12-24 EX DG HSM, 28/2.8, 50/1.8, 24-105L IS USM, Sigma 70-200 2.8 EX DG HSM
420EX, Sigma 1.4X Converter, Moded Off-Shoe Cord 2, 2x1Gb + 1x2Gb, Pelican 1550 Case, Hoya IR72, Mono-Tripod.
2,152 views & 0 likes for this thread, 10 members have posted to it.
2264 guests, 125 members online
