Thread started 05 Aug 2006 (Saturday) 08:40
AMAZING cleaning procedure for optical surfaces
SkipD
Joined Dec 2002
Aug 05, 2006 08:40 |  #1
I have just learned an amazing method for cleaning optics that I want to pass on.
I attended a class on some laboratory analyzers that measure particle sizes (all the way down to particles that you cannot see) using three lasers, lenses, and front-surfaced mirrors, in addition to the sensors in the optical path. As you may imagine, the optics in these machines are extremely sensitive to dust, scratches, and anything deposited on them.
The surfaces of the front-surfaced mirrors (the mirror surfaces are actually deposited on the outside of prisms) are probably the most delicate of the optical surfaces when it comes to cleaning. If they are dirty, most folks using lens tissues and lens cleaning fluid would tend to create a haze of tiny scratches on the very delicate mirror coatings. Thus, the lab supervisor experimented quite extensively and came up with the following procedure that is astoundingly simple and works perfectly every time for him. He uses it for every lens in the system.
Before I progress, I must say that the lenses are not like camera lenses. Several are single elements which are mounted to adjustable stands. The stand can be removed and reinstalled on reference pins, and the lens can be removed still attached to the stand without affecting the adjustments themselves.
The cleaning procedure requires removal of the lenses or mirrors from the analyzer. Thus, you are not going to be able to use this procedure for an SLR’s mirror.
Here are the steps:
1. You will be working at a sink with either de-ionized water or highly filtered water available through a faucet.
2. The key product is Dawn dish detergent. Do not substitute other brands. The contents of Dawn were determined to be ideal for this work, and other detergents are not the same.
3. After getting all the cleaning materials and the lenses/mirrors to be cleaned together near the sink, wash your hands thoroughly using the Dawn dish detergent.
4. Rinse the optical device a gentle stream of water – use no significant pressure to the stream.
5. Apply a small blob of Dawn detergent to the surface.
6. While holding the optical device under the running water, use your (cleaned) finger to swirl the Dawn around and clean the entire surface.
7. While holding the optical device under the running water, keep running your finger over the whole surface until you finally feel a “squeaky clean” surface under your finger. The feeling is very much like that when you run your damp finger around a fine crystal glass and make it “sing”.
8. The optical surface is now clean, and the trick is to be able to get it dry without touching it.
9. Holding the optical surface at an angle, you let the water stream trickle over the highest edge and start pulling the optical surface up and away from the water stream. The water will sheet over towards the lower edge. This is a tricky step, but a little practice will make it work for you. At the very end of this process, you will have a totally dry surface except for the lowest edge. Remove the optical surface totally from the water stream.
10. Using the corner of a lens tissue, just touch the remaining water at the edge of the optical surface and let it “suck” the remaining water off without touching the optical surface itself.
I would not suggest using this procedure for many camera lenses, as you may get water inside the lens. However, it is an absolutely perfect procedure for photographic filters (glass ones, that is), front-surface mirrors, and lenses that you can get to the sink and not risk damage from the water.
What damages so many optical surfaces is bad cleaning procedures. Particles that may be too small to see often get ground into the surfaces of lenses, filters, and front-surface mirrors, and cause tiny – but significant – scratches in the surfaces. This procedure, when done properly, totally eliminates this. In addition, the haze (often colored – usually tending to be purple) that you often see on a freshly “cleaned” lens is never seen with this procedure.
Skip Douglas
willg
Aug 05, 2006 10:27 |  #2
Are we sure that any coatings will not be affected by dawn?
5D, 300D, Tamron 17-35mm f/2.8-4, Canon 70-200mm f/4, 135mm f/2, 24-105mm f/4, 50mm f/1.4, Sigma ef 500 dg super, Canon 580EX
http://www.spideronthe​floor.com/ (external link)
SkipD
Joined Dec 2002
Aug 05, 2006 11:53 as a reply to  @ willg's post |  #3
According to the engineers I spoke to, the optics coatings in the particle size analyzers are more fragile than those used in today's cameras and filters. Those coatings are not affected by the procedure.
Skip Douglas
NickSim87
Sir Chimp-a-lot
Aug 05, 2006 12:13 |  #4
Remind me never to wash my hands with anything other then Dawn.
Gear List | Feedback
Kodama
Aug 05, 2006 12:54 as a reply to  @ NickSim87's post |  #5
Thanks for the tip! Don't think i'll try it with my lens, but i'll give it a go with my sunglasses.
Sam
Aug 05, 2006 13:05 as a reply to  @ Kodama's post |  #6
Dawn is also the soap of choice for stripping the wax and road grime off of your car before you detail it :D
mspringfield
Joined Jun 2005
Aug 05, 2006 13:18 |  #7
Several years ago a friend of mine who makes his own telescopes spoke with and engineer from Meade, an optical company known for making telescopes, who also mentioned Dawn dishwashing detergent. Their suggestion was to make a 50-50 mixture of 90% alcohol (not the standard stuff in your medicine cabinet) and distilled water. To that mixture add a couple of drops of Dawn dishwashing detergent and shake well to mix. You can then use a lint free cloth the clean the surface of any glass surface. According to Meade it will not harm their coatings. I have never used it on my Canon lenses but it worked fine on my Nikon glass so I don't see why it wouldn't work on Canon.
Michael
Michael Springfield - Chattanooga, TN
Canon 1DsMkIII, Canon EOS M, Canon 70-200mm 2.8L IS, Canon EF 1.4x II
FlashZebra
This space available
Aug 05, 2006 14:09 |  #8
I have cleaned camera filters, sunglasses, magnifying glasses, etc. using a method very like this for years. But, I used whatever dishwashing liquid I happen to have at the sink.
I even used a method near this on a couple of old LP records that had become unusually dirty.
I have noticed no ill effects to any of the cleaned objects.
Enjoy! Lon
Meaty0
Mar 06, 2008 15:48 |  #9
Kodama wrote in post #1812986 (external link)
Interesting method. I've seen ultrasonic cleaners used similarly, but agree with Kodama, no streams of water will be passing over my camera lens surfaces...I hope:shock:
I'll just have to stick to silicone lens cleaner spray and a scrupulously clean, microfiber cloth.
ben_r_
-POTN's Three legged Support-
Mar 06, 2008 15:50 |  #10
solinger wrote in post #1813013 (external link)
For some... Many consider it too harsh on rubber and plastic and highly advise against it. There are all kinds of threads on it at autopia.org for those who dont already know about it and are interested in car detailing.
scottgee1
Joined Mar 2004
Mar 06, 2008 15:57 |  #11
It's also the "secret ingredient" used by a lot of professional window washers. They add a couple drops to a gallon of their regular solution.
Wonder what's in it . . . ???
Lazmeister
Mar 06, 2008 16:19 |  #12
scottgee1 wrote in post #5061951 (external link)
Depleted Uranium.
Rick 'with a silent P'
"The thread hogging blunder from Down Under"
scottgee1
Joined Mar 2004
Mar 06, 2008 16:33 |  #13
Lazmeister wrote in post #5062117 (external link)
Depleted Uranium.
:lol:
Ah, so it's Nuclear Dawn.
Double ­ Negative
*sniffles*
Mar 06, 2008 16:33 |  #14
I've been using this "secret technique" to clean eyeglasses for years... :)
What Sam said is also true - it removes wax from your vehicle. Do not use dish soap (especially Dawn) to wash your car!
This should work on weathersealed L lenses... Just kidding. Don't do it.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
Wilt
Mar 06, 2008 16:35 |  #15
Like FlashZebra, I have used similar technique to clean groundglass focusing screens and plastic focusing screens for cameras that have removeable screens, and I also did not employ a specific brand of detergent. I did follow up with a dunk/swirl around a container of distilled water, though, so that any residual water did not dry and leave a spot of minerals on the air drying suface.
5,176 views & 0 likes for this thread, 18 members have posted to it.
1543 guests, 135 members online
