Thread started 07 Aug 2006 (Monday) 09:07
White ballance or metering?
Ephemeral
Aug 07, 2006 09:07 |  #1
I was out shooting some dragon boat event and mid way through there was a lion dance performance.
The two images below are shot more or less at the same time. My question is, is it the white balance that's causing the images to appear different or the way I was metering the scene? (They were intentionally under-exposed by a stop)
As you can see, the backgrounds appear very different. I normally shoot in RAW, but I left the camera in JPEG as I was doing some continuous shooting.
Canon 5D + Grip | 85mm L f/1.2 | 17-40mm L f/4.0 | [COLOR=Silver]24-70mm L f/2.8 |[COLOR=Black] 70-200mm f/2.8 L IS | Speedlite 580EX & 430EX | Manfrotto 190Pro + 488RC2
ephemeral.smugmug.com (external link)
woffles
Aug 07, 2006 10:13 |  #2
I'm sure it's metering. Notice you have a dark subject in the center of your first picture and the ground is lighter. In the second you have a lighter subject and the ground is darker. The camera metered off the center of the frame. Situation like this is a good use of manual. You could use an 18% grey card and meter off of it and just use those settings.
Film is what you get when you don't brush your teeth.
SkipD
Joined Dec 2002
Aug 07, 2006 10:25 as a reply to  @ woffles's post |  #3
That analysis is absolutely correct.
Skip Douglas
Ephemeral
Aug 07, 2006 10:33 as a reply to  @ SkipD's post |  #4
Thanks!
I will need to practice more in manual mode. :cool:
960 views & 0 likes for this thread, 3 members have posted to it.
1801 guests, 121 members online
