Thread started 07 Aug 2006 (Monday) 14:13
PORTRAIT PRACTICE
wagonwheel
Aug 07, 2006 14:13 |  #1
I had a little free time to kill today so I did a little black & white conversion practice. I am not sure if I like what I ended up with or not. Any thoughts? Now that I look at it again, I think it is a bit dark.
HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by PICTURETRAIL
Lovin' my 80D
Take a look:https://dwjimages.smug​mug.com/ (external link)
98photo
Aug 07, 2006 14:15 |  #2
Where's the photo?
hwyhobo
Aug 07, 2006 14:41 as a reply to  @ 98photo's post |  #3
It looks somehwat flat to me. If the current conversion was my starting point, I would try gradient map and then final touches with levels.
I cannot say what I would do if I had the original because I didn't see it.
As for the background, if you try levels after the gradient map, and you try to bring up highlights a bit to make the face more 3D, the brighter spots of the background will burn.
wagonwheel
Aug 07, 2006 19:12 |  #4
Can you give me a quick lesson in gradient map? I just gave it a try—WOW! I guess I need to dig out that Photoshop book. I use Photoshop Elements 3.0. Any advice is appreciated.
Lovin' my 80D
hwyhobo
Aug 07, 2006 21:53 as a reply to  @ wagonwheel's post |  #5
Not much I can teach you beyond what you can discover in 10 minutes of experimenting. :D Remember to click on the window with the gradient to adjust it to your liking.
I do not always use it. In fact, I use it maybe in 30% of conversions, sometimes as a supplement to another technique.
I also noticed that it makes a difference how you pre-process the image in color before you start a conversion, and that changing B&W later gives different results. In other words, some changes I do in color, then the rest in B&W.
wagonwheel
Aug 08, 2006 08:47 |  #6
I read what was offered in my Photoshop books (not much). Like you said, it is something I will have to play around with in order to learn. Thank you for pointing me in that direction. It is a new tool in the tool box.
Lovin' my 80D
1,215 views & 0 likes for this thread, 3 members have posted to it.
PORTRAIT PRACTICE
942 guests, 109 members online
