Thread started 07 Aug 2006 (Monday) 14:38
What program to load photos from the camera?
Scorper
Aug 07, 2006 14:38 |  #1
What program do you use for loading the pictures from the camera to the computer? I've been using the standard Zoombrowser but I cant find a way to stop it starting Zoombrowser after the loading is complete, since I dont use it for anything (archiving done via Picasa and raw conversion done via photoshop).
Some people just "drag and drop" the files from the camera in explorer but this seems kinda tedious because theres several folders filled with pictures in the card, and you have to manually create a folder with the date on. And I dunno but my 350D shows up as a camera in explorer and just contains folders with no names and it shows only .jpg photos, doesn't show raws (not sure if it will copy the raws too if I copy the whole folder).
Is there any nice and pretty simple program that functions pretty similar to Zoombrowser download window? So that it wont load pictures already in the hd and can create new folder with the date on etc.
350D + BG-E3 + kit lens + 50mm F1.8 II
weemannie
Aug 07, 2006 14:42 |  #2
Take a look at Breezebrowser Pro. That may do want you are looking for. :)
Regards, Trevor
5D MkIII, 60D, Zuiko 24mm, Zeiss ZE 21mm and 50mm 1.4, 70-300L, 10-22
http://www.scotlandima​gery.com (external link)
coreypolis
Aug 07, 2006 14:51 |  #3
if you're already using picasa, try that, just click import
Photographic Resources (external link) || International Photo Journalist (external link)
Blog (external link)
Seattle Wedding Photographer - Corey Polis Photographer (external link)
Scorper
Aug 07, 2006 15:15 |  #4
Hey Corey, thanks for the idea but it seems that Picasa wont load my pictures. It just says no pictures to show when I select my 350D. Any ideas?
Edit: Seems that "EOS utility" functions exactly like the Zoombrowser download window except I can set "Link images" to "none".
René ­ Damkot
Aug 07, 2006 15:36 |  #5
Buy a card reader...
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
coreypolis
Aug 07, 2006 15:39 as a reply to  @ René Damkot's post |  #6
while a good investment, that really doesn't solve his problem.
I'm not sure why picasa won't read it.
René ­ Damkot
Aug 07, 2006 15:48 |  #7
True. Sorry...
Might be that Zoombrowser is interfering with Picasa? I think I've seen posts before where windoze machines had trouble 'seeing' CR2 files when the camera was used instead of a card reader...
edit: threads:
1
might help as well:
2
3
corinto
Aug 07, 2006 15:55 |  #8
Scorper wrote:
...it shows only .jpg photos, doesn't show raws
Upgrade ZoomBrowser from Canon. The new version sees (and copies) RAW files.
Julio.
http:// …
Titus213
Aug 07, 2006 16:02 |  #9
I use a program called Downloader. It has an option for recognizing the camera but I've never used it since my box has built in card readers.
Dave
Perspiring photographer.
Scorper
Aug 07, 2006 16:08 as a reply to  @ corinto's post |  #10
I was talking about using explorer to copy files from the camera :)
cfcRebel
Aug 07, 2006 16:46 as a reply to  @ Scorper's post |  #11
Then back to Rene's recommendation - card reader.;)
Fee
Canon | SIGMA | TAMRON | Kenko | Amvona
tim
Light Bringer
Aug 07, 2006 21:11 |  #12
Card reader.
DIM from http://www.alanlight.c​om (external link)
1,289 views & 0 likes for this thread, 8 members have posted to it.
1047 guests, 105 members online
