Thread started 07 Aug 2006 (Monday) 20:51
Worksheet for DOF parameters
hecya
Aug 07, 2006 20:51 |  #1
I have created an Excel worksheet that shows the DOF and its dependance upon several parameters like the distance to the focused object, the aperture and the focal length of the lens used.
So you can see how the DOF varies when changing only the aperture while keeping all other parameters fixed. Likewise you can see the effect to DOF of only changing the distance or the focal length.
I think it might be of interest to some of you.
It uses macros to choose the parameter to be varied by the user.
EOS 20D
SpeedLite 420EX
Tamron 28-75 mm f2.8 XR Di
Tamron 70-300 mm F/4-5.6 Di
Bogen 3021Pro Tripod
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Aug 08, 2006 09:35 |  #2
Good idea. This may help visualize the results, too:
Virtual Camera
http://www.camerasinte​ractive.com/index.php# (external link)
cecilc
Joined Mar 2004
Aug 08, 2006 10:27 |  #3
hecya wrote:
I have created an Excel worksheet that shows the DOF and its dependance upon several parameters ...
Not to minimize the work you've done, but doesn't this do the same thing ... ?
http://www.dofmaster.c​om/dofjs.html (external link)
Or am I missing something ?
Cecil
Maxpreps Galleries (external link)
coreypolis
Aug 08, 2006 10:29 as a reply to  @ cecilc's post |  #4
because his is a xls worksheet, you could put it on a pda or some mobile phones on the go
Photographic Resources (external link) || International Photo Journalist (external link)
Blog (external link)
Seattle Wedding Photographer - Corey Polis Photographer (external link)
StewartR
"your nose is too big"
Aug 08, 2006 10:47 as a reply to  @ coreypolis's post |  #5
Personally I'm afraid I don't think this is very useful as it stands.
  • It is not at all clear which cells are user inputs and which ones are calculated. As a result it's not clear what the user can and can't do with the spreadsheet.
  • Also, there are cells that ought to be linked but don't seem to be. For example, in the 'camera' section I can apparently set a range of focal lengths (e.g. 18-55mm), and that changes the effect of the slider in the 'focal length' section, but neither of those are linked to the focal length entry in the 'composition' section.
  • Another weakness: why allow values such as 5.7 and 23 for aperture, but not standard ones like 5.6 and 22?
I'm afraid I won't be using this.
www.LensesForHire.co.u​k (external link) - complete with matching POTN discussion thread
Photos: Cats (external link) | London by day (external link) | London by night (external link) I My POTN photo sharing threads (external link) | Official "Where Am I Now?" archive (external link)
Gear: 350D | Sigma 18-200mm | EF-S 10-22mm | EF 50mm f/1.4
hecya
Aug 08, 2006 16:57 |  #6
Stewart, the numbers used for the aperture are the ones coming from a mathematical calculation. They rounded up to 5.7 and 23.
In the Camera section the user only specifies the minimum and maximum focal lengths and so the slider has to change accordingly. In the Composition section the user inputs the actual focal lenght used for a particular shot he wants to analyze
Regarding the inputs I agree with you and I will be marking the input files in a different color to make clear which are inputs.
Thanks for your feedback.
EOS 20D
SpeedLite 420EX
hecya
Aug 08, 2006 17:05 |  #7
cecilc: I know the web site you refer to. It is very useful but I wanted something more dynamic. Instead of entering values one by one to see what is the effect I think is better to have sliders that inmediately inform you about the effect of any given parameter on the DOF. I also added the physical size of the area covered by the sensor. I think is very useful if you are planning ahead a shot.
Thanks for your time trying the worksheet.
EOS 20D
SpeedLite 420EX
rhys
Dis-Membered
Aug 09, 2006 12:58 |  #8
I prefer something tabular where you could have tables of values for say:
17, 24, 28, 35, 50, 75, 135 lenses (the most commonly used) - one table per lens - giving focussing distances in feet from 1 to 20 and the depths of field at apertures from f2.8 to f22 (the most common).
Rhys
The empire conquers yet more galaxies:
www.sageworld.co.uk (external link)
www.sageworld.org (external link)
www.sagephotoworld.com (external link)
Blog: http://360.yahoo.com/t​hunderintheheavens (external link)
Free cheese comes only in mousetraps
hecya
Aug 09, 2006 19:32 |  #9
Tables are easier to consult but the problem is that the number of variables involved is too great: aperture, distance, focal length are all involved in the DOF. So it is necessary 3 sets of tables. In the worksheet you can cjange each variable on its own.
EOS 20D
SpeedLite 420EX
Hellashot
Joined Sep 2004
Aug 10, 2006 11:31 |  #10
I've seen other posts in the past of excel versions of other calculators. Guess you re-invented the wheel. :)
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
hecya
Aug 10, 2006 19:10 |  #11
You are right. The results shown are by no means new or special. I hoped to present the results in a more intuitive way.
EOS 20D
SpeedLite 420EX
1,148 views & 0 likes for this thread, 7 members have posted to it.
1842 guests, 108 members online
