I am very tempted by this lens, to replace a Canon 70-200 f/4 L and a 300 f/4 L prime. While I do not expect it to be quite as good as the prime a number of people, and a number of reviews, suggest that it should be as good as the 70-200, even at f/4 and max focal length. The review here, for example, shows excellent MTF figures at 300mm f/4: Photozone review
(better than at f/8, in fact, and better in the centre than the Canon 70-200 at 200mm f/4).
I have been looking at getting one second hand, and the samples that I have seen from these lenses are soft at 300mm f/4. Doing further searching, I then found a review, with sample shots, at Photodo Canon review
which seems to confirm the softness (also, look at their MTF charts). If you look at their review of the 70-200 f/4 (Photodo Canon review
) the sample shots at f/4 and the MTF are much better.
What do people think? Can the Sigma be in the same ballpark as the Canon (in which case sample variation seems to be a problem), or should I expect it to be soft at f/4?
You never seen any complaints about it either. I would say a very safe buy and used well is pretty well up there with the very best.
