Thread started 09 Aug 2006 (Wednesday) 20:53
i want to take a shot of the moon tonight
troyer16
Aug 09, 2006 20:53 |  #1
recomended settings? any help? low iso, high iso? aperature? shutter speed? thanls
Canon Digital Rebel XT (350D)
Canon Rebel X (Film)
Canon EF 17-40 f/4 L
Tamron EFS 70-300mm/Macro
www.adamtroyerphotogra​phy.com (external link)
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Aug 09, 2006 21:08 |  #2
Let's see .... Rebel XT.
Just for starters, good, solid tripod. ISO 400. f/8 & 1/320 second exposure. Bracket that exposure +/- 1 stop or so, and shoot in RAW to allow more room for adjustment. Use mirror lockup and a remote shutter release. If you don't have a remote release, use the built-in timer instead.
Look at your results and adjust from there. You may find that with your lens, f/11 is better. Or maybe not. Experiment.
Tom
5D IV, M5, RP, & various lenses
Mark_Cohran
Joined Jul 2002
Aug 09, 2006 21:13 |  #3
Everything Tom said plus try to catch the moon low on the horizon. It will seem larger and appear to have a better color.
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Aug 09, 2006 21:23 |  #4
... But not too low as you'll be shooting through more atmosphere, and that will also present a bit of softness.
If you're in a city with lots of lights and some smog, you'll have to wait until it's fairly high in the sky to get the cleanest shot. Out in the country, the air is generally cleaner and the artificial lighting is minimal.
Tom
troyer16
Aug 09, 2006 21:29 |  #5
thanks guys, im a little unsure of why to use the mirror lock up. i have no remote
misspix
Misscreant
Aug 09, 2006 21:48 |  #6
Mirror lock up reduces camera shake. Thanks for the thread, I have had a hard time with the moon, too. For some more info:
https://photography-on-the.net/forum/showthre​ad.php?t=201717
kfong
Joined Jun 2003
Aug 10, 2006 00:35 as a reply to  @ Tom W's post |  #7
Tom W wrote:
Just for starters, good, solid tripod. ISO 400. f/8 & 1/320 second exposure. Use mirror lockup and a remote shutter release. If you don't have a remote release, use the built-in timer instead.
Mirror lock, remote shutter release and tripod are not necessary at 1/320 second exposure at focal lengths less than 400 mm.
Ken
StewartR
"your nose is too big"
Aug 10, 2006 04:58 as a reply to  @ Mark_Cohran's post |  #8
Well, the colour is real, but the apparent size isn't. It's just an illusion. Check out Wikipedia: Moon illusion (external link) for example.
When you're trying to judge the exposure, it might help to know that the albedo of the moon (i.e. its reflectivity) is in the range of 7% to 12%. (Sources disagree.) That's considerably darker than the 18% grey which your camera's meter expects. So to get the exposure right, in theory you'd need to meter off the moon and then set the exposure compensation to somewhere between -2/3 and -1 1/3 stops. As Tom W suggests, bracket the exposure and shoot in RAW to allow more room for correction - but I'd be tempted to bracket around -1 stop (e.g. -2, -1, 0).
Have fun and don't forget to post your results!
www.LensesForHire.co.u​k (external link) - complete with matching POTN discussion thread
Photos: Cats (external link) | London by day (external link) | London by night (external link) I My POTN photo sharing threads (external link) | Official "Where Am I Now?" archive (external link)
Gear: 350D | Sigma 18-200mm | EF-S 10-22mm | EF 50mm f/1.4
Franko515
"doped up on pills"
Aug 10, 2006 05:03 as a reply to  @ StewartR's post |  #9
My moon shot question
Thanks in advance
Light, composition, shooting technique matter to the end quality most. -Pekka
My Flickr Gallery (external link)
My Gear List
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Aug 10, 2006 05:23 as a reply to  @ kfong's post |  #10
Ken
If you want to do the experiments, you can. I did. Considering that the final image will have to be viewed at something close to 100% to fill the monitor, you will see a difference, even at the "short" focal lengths of less than 400 mm. IS would make a difference as well, but I don't see that he has an IS lens in his equipment list.
And yes, despite the proverbial statement that mirror lockup doesn't make a difference above 1/30 or 1/60 or whatever shutter speed, that isn't necessarily true either. Yes, it's a good rule of thumb for small or medium prints. But once again, when dealing with an object that is going to be viewed at 100%, every minute movement will show up. It will be the difference between craters that are crisp and sharp, and craters that don't have a detailed presence.
I'll put it this way - I've shot the moon with my 100-400 IS lens on and off the tripod. Even with good shutter speeds of 1/400 to 1/640, I gain a higher percentage of crisp shots with the tripod, mirror lockup, and the remote release than I do handheld without the remote and without mirror lockup. And that's with the benefit of the IS, which helps a great deal as well.
Tom
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Aug 10, 2006 05:42 |  #11
Here's what I'm trying to say, Ken. Here is a shot of the moon at 400 mm on a 30D:
IMAGE: http://www.pbase.com/photosbytom/image/64929868.jpg
Viewed as a whole image, any tiny vibration or motion caused by camera shake or mirror vibration won't be visible. But given that the moon is such a tiny portion of the image, we'll want to view it as something much closer to the full screen size. I took the liberty of enlarging this image to 100% and cropping out just a 700X700 pixel square around the moon. Now at this level of magnification (probably the wrong word), any minute movement will be visible:
IMAGE: http://www.pbase.com/photosbytom/image/64929869.jpg
I took several quick shots of the moon this morning, handheld - this one is the sharpest. Most were pretty good, and a couple were rather soft. The ratio of good-soft images goes way up with the more stable mount.
EXIF: Canon 30D, 100-400 L IS, f/7.1, 1/400 sec, ISO 400. Shot RAW and pulled down 2/3 stops in DPP. Also cranked up the contrast in DPP a good deal to show some contrast.
Tom
superdiver
Aug 10, 2006 17:58 |  #12
OK, what exactly is "mirror lock up" and why do we need to do it?
I just hot with a remote so as not to jiggle the tripod with my clumbsy fingers...what does the mirror lock up do?
40D, davidalbertsonphotography.com
Newbie still learning
kfong
Joined Jun 2003
Aug 10, 2006 19:11 as a reply to  @ Tom W's post |  #13
Both of the pictures of the moon have N & S inverted.
I would suggest that inaccuracy in AF and seeing condition has more to do with softness than mirror shake.
Ken
bbqKing
"...less likely to get nailed"
Location: At the corner of Brush Hogging and Hay For Sale
Aug 10, 2006 19:37 |  #14
Do a search for The Shaytech Moon Exposure Calculator. Sorry i don't have the link but it helps alot
Tom ­ W
Canon Fanosapien
Joined Feb 2003
Aug 10, 2006 19:52 as a reply to  @ kfong's post |  #15
Ken
What is N & S?
Both are the same picture.
Tom
3,916 views & 0 likes for this thread, 11 members have posted to it.
1842 guests, 108 members online
