Thread started 11 Aug 2006 (Friday) 09:55
Better to overexpose or to use FEC?
fi20100
Slightly late
Aug 11, 2006 09:55 |  #1
When shooting with flash, Speedlite 430EX on my 350D, I feel that every now and then the pictures come out a bit underexposed. I mostly use P mode. Is it better to overexpose a bit or to use FEC to get more power out of the flash?
Does anyone have any opinions on this one?
-Fi20100
Stefan
5D3, 5Dc, 5Dc, 40D + 17-40L, 24-70L, 70-200L, 50/1.4, 85/1.8, 100L Macro and some other stuff.
flickr (external link), 5∞px (external link)
davidfig
we over look the simplest things
Aug 11, 2006 10:05 |  #2
My answer would be yes.
If you overexpose you may run into slow shutter speeds, if you increase flash you may run into burnout. So really the conditions will dictate. You may want to experiment to see what works in your situation.
5D | 17-40L | Tammy 28-75 2.8 | 28-135 | 50/1.8 | 85/1.8 | Sony A6000 2-Lens Kit | SEL35 1.8 | EF 50 1.8 on NEX as my 75mm 1.8
stupot
Aug 11, 2006 10:09 |  #3
if you are in ettl mode, then overexposing using the camera controls will just cause the flash to compensate and reduce power... so you'll probably still have the same underexposure problem. in which case, use FEC
Canon EOS 350D, Sigma 10-20 f4-5.6, 24-105 f4L IS, 70-200 f4L, 300 f4L IS, Kenko 1.4x pro300, 430EX, Apple Powerbook G4
Free filters for your flashgun!
fi20100
Slightly late
Aug 11, 2006 10:14 |  #4
So I guess, when in a situation where there's time to experiment, just put both the camera and the flash into M :) And when there's only time for one try, USE E-TTL2 and put FEC to +1/3 ;)
-Fi20100
Stefan
1,068 views & 0 likes for this thread, 3 members have posted to it.
1408 guests, 109 members online
