This is probably a dumb question, but it will be dumber if I don't ask. I just got a Hoya Digital Pro1 Circular Polarizer. It's got an outer rotating part (where the filter is mounted), with a little arrow in one spot. I see that the effect changes as I rotate the filter. The "indicator" is not always up, so I end up rotating it slowly until I find the position with the most contrast or least glare. Makes sense, kind of like polarized sunglasses. However, it's a major pain. Of course, I can't adjust the filter with the hood on. So the hood comes off. Second, it just takes time.
Am I using it wrong? Is there a simple technique to make this a bit easier? Thanks!
