Hi all,
Can someone tell me if these flash bracket will work with 1D Mark II or any suggestion for me, or even other brand? Thanks alot!
- Stroboframe Camera Flip
- Stroboframe StroboFlip![]()
sam0329 Senior Member 540 posts Joined Jul 2005 Location: Edmonton Alberta Canada More info | Aug 13, 2006 17:32 | #1 Hi all,
coreypolis Cream of the Crop 6,793 posts Likes: 4 Joined Mar 2005 Location: Mercer Island, WA More info | Aug 13, 2006 17:52 | #2 Permanent bantheres not going to be much of a height difference in landscape mode, if it filts at all. I'd look into custom brackets Photographic Resources
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Aug 13, 2006 17:54 | #3 Can't answer your question about either of the Stroboframe flips you mentioned but I do know that the Stoboframe Pro-L brackets will work with the 1DmkII. The Pro-L will require an anti-twist plate (300-BE1), though. ...Leo
SuzyView Cream of the Crop More info | Aug 13, 2006 18:22 | #4 Take this thread food for thought. Suzie - Still Speaking Canonese!
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Aug 14, 2006 07:09 | #5 I have the Stroboframe camera flip. It works well on my 20D without a grip, but on the taller 1D series cameras, the sync cord end on the hotshoe will interfere with the bracket in vertical orientation. The flash flip models from Stroboframe will probably work ok, but there are better brackets out there. I'd follow coreypolis' advice. "If you're not having fun, your pictures will reflect that." - Joe McNally
sam0329 THREAD STARTER Senior Member 540 posts Joined Jul 2005 Location: Edmonton Alberta Canada More info | Aug 14, 2006 13:42 | #6 Thank you for all you guys comment
Viking44 Hatchling 1 post Joined Mar 2006 Location: Michigan More info | Feb 13, 2007 21:52 | #7 sam0329 wrote in post #1847449 Hi all, Can someone tell me if these flash bracket will work with 1D Mark II or any suggestion for me, or even other brand? Thanks alot! - Stroboframe Camera Flip - Stroboframe StroboFlip Hi there,
RonnieRay69 Member 31 posts Joined Jan 2007 Location: Oange County, Ca. More info | Feb 14, 2007 04:20 | #8 I have a newer version than that and mine works fine for the 5D but you have an extender for the hotshoe mount and flash mount you need to slightly extend it to clear the top of the camera but in the sideways position it fits fine cause it's pointing away. 5D, XT, EF-S17-85f/3.5-5.6, 430EX, 580EX, EF24-70f/2.8L USM, EF70-200f/2.8L IS USM, Alien Bees 800 X2, ABR800 Ring Flash, ETC.........:p
RonnieRay69 Member 31 posts Joined Jan 2007 Location: Oange County, Ca. More info | Feb 14, 2007 04:23 | #9 Here is the link http://cgi.ebay.com …em=280069097532&rd=1&rd=1 5D, XT, EF-S17-85f/3.5-5.6, 430EX, 580EX, EF24-70f/2.8L USM, EF70-200f/2.8L IS USM, Alien Bees 800 X2, ABR800 Ring Flash, ETC.........:p
| Latest registered member is Marcsaa 658 guests, 120 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
