Thread started 14 Aug 2006 (Monday) 12:57
Why use a head unit on a monopod?
KAS
Aug 14, 2006 12:57 |  #1
I have read on several occasions in this forum that people use a ball head on their monopod. My question is why? It's a stick. It can easily rotate on the ground. and I also don't see why, unless you had the monopod at an odd angle to the ground, why you'd even need a fully adjustable head. If it's being held at such an odd angle, just hand hold.
I have a monopod, and I have never found a use for a complex head unit yet.
Just my observation, and curiosity.
-Kirk
1Ds MkIII, 70-200 f/2.8L IS II, 16-35 f/2.8L II, EF 100mm F/2.8, EF 35 f/1.4L, EF 50 f/1.2L, EF 85 f/1.2L II)
| Niagara Weddings & Portraits - Afterglow Images (external link)
| Niagara Weddings & Portraits - Afterglow Images Blog (external link)
Phil_Mart
Aug 14, 2006 13:15 |  #2
I have a Manfrotto mono pod and a head for it. Reasons being a, the head has a quick detachable mounting plate that I can leave on the camera, simply click on and off and b, have you ever tried going to portrait (vertical) mode with a mono pod ;)
Philip Martin
__________
350 D + Battery Grip
Kit EFS 18-55mm Lens, EF 50mm II, EFS 17 - 85mm IS USM, EF 75- 300 USM. 100 - 400mm IS USM L
Manfrotto 676B monopod & 234RC head. Lowepro Back-pack,
Wacom Graphire Classic XL (this is great!).
KAS
Aug 14, 2006 13:33 |  #3
ah...portrait...never thought of that. duh. that was short-lived confusion.
I don't shoot a lot of portrait...which is perhaps why I didn't think of it.
-Kirk
cecilc
Joined Mar 2004
Aug 14, 2006 14:02 as a reply to  @ KAS's post |  #4
I screw the monopod directly into the foot of the lens' tripod collar....
And, usually, any lens that's heavy enough to USE a monopod with (a few that come to mind: 70-200 2.8; 100-400 5.6; 300 2.8; 400 2.8; etc.) have their own tripod collar that rotates ... so it's easy to go from horizontal to portrait even attached directly to a monopod. And I go from landscape mode to portrait mode at the turn of lock ....
I've tried to use a ball-head on a monopod, but was totally unsuccesfull with it - no amount of tightening the ball head could prevent my 400 2.8 from dipping and wobbling all over the place ... I just never could keep it steady and level ...
So, for me, monopod only - no ball head .....
Cecil
Maxpreps Galleries (external link)
AccidentalArt
Aug 14, 2006 14:13 as a reply to  @ cecilc's post |  #5
the quick release it worth it alone, but another benefit is the ability to sqaure the picture in the event the camera cannot be directly above the foot of the tripod. I would not have guessed it until I got mine, it made things way simpler.
AA
7D, RebelXT, 30D, 50mm 1.8, 85mm 1.8, Sigma 70-200 2.8 Macro, Sigma 1.4x TC, Tamron 17-50 2.8, Metz 54, 100-400IS, Kenko Ext Tube Set, 24-70 2.8, 180mm Macro, (2) GoPro
CoolToolGuy
Boosting Ruler Sales
Joined Aug 2003
Aug 14, 2006 14:25 as a reply to  @ cecilc's post |  #6
I have ball heads on both of my monopods. I wouldn't have it any other way.
When I am using it for motorsports I like that I can pan or adjust as the cars come at me without having to alter my stance. With a large lens, the tripod ring is essential to keep the whole rig in balance. Vertical (portrait) orientation is another reason.
The other interesting use of a monopod for me was shooting high school plays. I sat in a seat in the orchestra pit and ran the monopod from my chest down to the floor at an angle and secured the bottom with my feet. The ball head allowed me to have the camera at that odd angle. It worked quite well.
My 2 cents.
Have Fun,
Rick
My Gear list
SoaringUSAEagle
Daddy Of The Crop
Aug 14, 2006 16:09 |  #7
I have considered getting a monopod... Maybe this Christmas!
5D4 | 50 1.4 | 85L II | 24-70L II | 70-200 2.8L IS II
chris ­ clements
Joined Mar 2004
Aug 15, 2006 13:47 |  #8
The monopod's foot should form the stationary third side of a tripod along with your 2 size 12 Nike's. So to avoid a shaky soft-shoe-shuffle you still need one plane of movement (up &down) on the monopod for anything that's not on the straight & level, such as aircraft or birds.
I use a Manfrotto head that just tilts up and down, rather than a full ball.
SkipD
Joined Dec 2002
Aug 15, 2006 17:02 |  #9
I use my monopod in many ways, including while I am sitting and waiting for some sort of animal or bird to do whatever I am waiting for it to do. The monopod could be at a very strange angle, and a ball head (Bogen/Manfrotto 486RC2) on top makes this sort of thing not only possible but quite practical.
Since I may be using the monopod with the camera in any position, the ball head is much more versatile than the one-way tilt heads.
Skip Douglas
KennyG
Joined Aug 2003
Aug 15, 2006 17:22 |  #10
It all depends on what you are doing with the setup. You never see pros using ballheads with monopods at sporting events when they have lenses with collars. You very quickly learn how to tilt as well as pan. With short lenses, even a 70-200 2.8IS, there isn't any need for a monopod unless you are in virtual darkness with a very slow shutter speed. Your own lens collection does not justify one, unless you do a lot of low-light work.
Ken
Professional Motorsport Photographer
2 x 1D MK-II, 7D, 17-40L, 24-70L, 70-200 2.8L IS, 100-400L,
300 2.8L IS, 500 4.0L IS, 85 1.8, 50 1.4, 1.4 & 2.0 MK-II TC.
Phil_Mart
Aug 16, 2006 05:25 as a reply to  @ KennyG's post |  #11
Disagree with KennyG here. You, as a pro photographer may well be able to hold a 75 - 300 (zoomed out to 300mm) perfectly stable, but I'll bet there are a shed load of people here that cant :(
Philip Martin
__________
Tandem
Joined Feb 2006
Aug 16, 2006 07:10 as a reply to  @ Phil_Mart's post |  #12
I find the ball head works great for lenses like the 70-200 f/2.8 IS that you can hand hold for a period of time but don't want to hold for long. After 4-5 hours it can make a BIG difference on how my back feels.
Bill - A model needs careful lighting, professional makeup and expensive clothes to look as beautiful as any ordinary woman does to a man who has fallen in love with her.
G10, 5D, 1D2n, 1D3, 1Ds3, 1.4x, 2x / 17-40 f4, 24-105 f4 IS, 70-200 f4, 300 f4 IS / 24-70 f2.8, 70-200 f2.8 IS, 200 f2.8, 300 f2.8 IS, 400 f2.8 IS / 35 f1.4, 50 f1.2, 85 f1.2, 85 f1.8, 100 f2.8M 135 f2
http://ColoradoSprings​.SmugMug.com/ (external link)
Thornfield
Joined Dec 2004
Aug 16, 2006 08:24 |  #13
Monopod with the lens mounted directly to it. For vertical shot's I leave the collar slightly loose. Shooting with a 70-200 2.8L non IS only so this might not apply if you don't have a lens collar.
Relationships are like photography, it has to click. :)
IainB
Joined Jan 2002
Aug 16, 2006 17:09 as a reply to  @ CoolToolGuy's post |  #14
Why not go for one more and you'll have a tripod.....;)
IainB
"Chi non ha moglie non ha padrone."
Mark_Cohran
Joined Jul 2002
Aug 16, 2006 17:09 |  #15
I have a ball head on my most used monopod for practically all the reasons stated above. I do have a monopod without the head which is a bit lighter, but I really seldom use it.
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
1,512 views & 0 likes for this thread, 15 members have posted to it.
2541 guests, 91 members online
