Hi!
Just thought maybe an out of the ordinary post might be something to make you think...
I had not thiought about it much, in this sense that in 12th grade (1996-1997) I took a Physics class and was it extrememly hard, but I feel I got the most out of it moreso than the French 5 class I almost slept thru and gave like no effort and still walked out with an A.
Ok, we have these bits called index (indices) of refraction, or how light as we know it bends/changes speed (relative to speed of light at 186,000 miles per second) thru various media like water, a glass you drink out of, a plastic soft drink container, other translucent/transparent objects, and of course camera lenses. This is in contrast to diffraction which is what you see like the prism bit. I was really bored at work (which is nothing new) and was wondering what causes Canon L glass to be so insanely expensive, vs the regular Canon lenses. Enter indices of refraction...the cheaper glass diffracts light differently and make for a much broader spectrum of light. Let's use the prism, as to how white light spreads out under diffraction. Then enter Canon's budget line of lenses and will probably diffract light not too different from the prism, all things being equal. Note how wide it is and how the colours can appear almost blending or murky. This is a high incidence of refraction comapratively speaking. The L glass, on the other hand using UD or Flourite elements cut down on chromatic abberations which I understand to be much more visible in the results of budget lenses. By cutting the incidence of refraction way down, again comparatively speaking, you also cut down the chromatic abberations. It is also my understanding that it is almost impossible to eliminate them entirely, but SLD/UD/Flourite elements sure help a lot there. The result is the much better pics we know when we use L glass. There is also a sharpness that I recon comes from the much lower incidence of refraction, as the size of the incident spectrum is much tighter than the budget lens as well. I find the science end of photography fascinating. This is what I found out when going from budget lenses to L glass! This is the most simple and to the point explanation I can come up. Hope it explains it on a more understandable level.
Cheers from England,
Canuck
