So, I have a decent picture, but I used a flash to illuminate the subject. In order to capture some ambient light, I bumped the ISO up a bit, and set up a little bit slower exposure. I shot in RAW format, so I basically set a ballpark temp, and shoot away. I got home, started setting up the raw conversion, get everything where I wanted it, and made my image files. During RAW conversion, I started to notice something bugging me about the picture. The lighting - it's mixed. There is a combination of flash illumination and weird fluorescent lighting. No matter what you do, something is off. The best decision is to adjust the WB for the subject. Since the subject in this picture is a group of people, you don't want them looking like Smurfs!
Here it is:
I actually like this photo a lot. It's nothing special - Al Meilutis, from The Polka Bandstand Show on Jazz 90.1
So I thought about this for a while, and I thought, what do I do with RAW files that don't contain enough range? Well I 'bracket and sandwich' or use HDR tools to expand it. Hmmm. I didn't bracket this, but wait! WB has almost no effect on quality of the image data - to a point. Exposure would be affected by different WB settings, but not by much at all. This will work. I'll blend different files from the same RAW source file, each with a WB for a specific part of the image.
Here are the three files I came up with:
Base File (5400/+5):
Ceiling (3300/+10):
Light Fixture (3900/+3):
I used the Base File as the background layer, and Shift-dragged and dropped the other two images on top using the Move tool in Photoshop CS2. For a quick look at how this would look, I clicked on each of the Ceiling and Fixture layers and used Layer > Layer Mask > Hide All to create a layer mask filled with black. This prevents any of the "WB adjusted" layers from showing. I used the Brush Tool with the foreground color set to white to paint on the layer mask where I wasted the WB adjustments to show through. This is a slow, painful process, and I am not a painter. My lack of skill at this kind of thing is what drew me to photography in the first place: all you have to do is push buttons. What I was doing was starting feel like painting. Here is snapshot of that first attempt:
Not bad, the difference between each of the regions corrected WB is a little drastic. By decreasing the Opacity of each layer, I was able to get it closer to a "balanced image."
I decided there had to be a better way. I decided to try running the TLR Professional Mask Toolkit script. Get it here
I did the same thing for Ceiling layer. Once all that was completed, I needed to tone down the edits. Reducing the opacity was enough to fix all that. I flattened (Ctrl-Shift-E), and continued with the rest of my usual workflow: noise reduction, capture sharpen, selective blur/sharpen/haze reduction, cloned out goobers, resize, output sharpen, saved as .jpg. Here is the final product:
Here is another look, side by side:
This is just a fast run with just three WB files. By rights, I should have used about seven. Another time. I like it better now, and I like the technique. Someone needs to come out with a program like Photomatix that does WB blends. Call it WhiBalMatix. Make a million dollars. Any one is free to add suggestions about how to improve the technique. For me, it's still a little raw. Get it? Raw.
I wouldn't mind at all if you posted the before and after here.
