Thread started 25 Aug 2006 (Friday) 22:43
So, how do you stop your sync lead from falling off?
FlyingPete
I am immune
Joined Oct 2003
Aug 25, 2006 22:43 |  #1
How do you?
I was shooting today with my new studio strobes and my 20D, they came with a rather heavy sync lead which I attached to my 20D, unfortunately gravity is almost enough to pull it out, if it doesn't a slight knock finishes the job.
In the end I wrapped it around my quick release plate for my tripod and taped it on with some small medical tape (sort of like narrow masking tape - leaves no residue).
Any other creative solutions to stop these pesky things from falling off?
Peter Lowden.
EOS R6 and assorted glass
Mark_Cohran
Joined Jul 2002
Aug 25, 2006 23:00 |  #2
I forego the synch lead altogether by using a wireless transmitter. Another trick you can use is to put a external flash on your hotshoe and put the flash in manual and run it down to minimum power and use it to slave fire your strobes.
With regards to your synch cable though, a small strip of gaffer's tape is the best bet. You can buy gaffer's tape in almost any photo supply store. It will not leave any sticky residue on your camera body.
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
FlashZebra
This space available
Aug 25, 2006 23:28 |  #3
Two recomendations.
It sound like the PC connection on your sync cord needs to be resized. Paramount cord sells an inexpensive device that forms the cord end to the correct size. This will tighten up the PC plug connection. This device is inexpensive and small, you can put it in your camera bag.
See:
http://paramountcords.​com/search.asp (external link)
After I plug in the cord, I just put a strip of tape across the PC connector and the camera body. I have used duct tape and 2 inch cello tape. But the gafters tape recommended above is likely a less messy solution.
Enjoy! Lon
FlyingPete
I am immune
Joined Oct 2003
Aug 25, 2006 23:35 as a reply to  @ FlashZebra's post |  #4
Thanks for the quick answers!
Hmmm I did think wireless as my strobes have IR sensors on them, they don't however trigger from other flashes, so using a flash at lower power on the camera is out.
Got a quote for a IR trigger, not cheap down this way part of the world, yet to check B&H for their pricing.
Will try the gaffer tape, I have a lot of duct tape (cloth tape), but it tends to leave residue. I also know everything is the correct size, it is just that a PC socket and plug don't have a lot of holding power in the first place, probably fine if it was connecting to a flash gun on the actual camera or on a bracket, but no good being dragged around a room :rolleyes:
Peter Lowden.
joeseph
"smells like turd"
Gallery: 263 photos
Joined Jan 2004
Aug 26, 2006 01:53 |  #5
For a technical solution as opposed to Heath Robinson, you could cable-tie a keyring clip to the sync lead about 100mm from the plug and clip the thing onto the end of the neck-strap loop (if not the actual neck-strap bracket then the strap loop itself should do) when being used - it should hold the weight just fine. :-)
e.g. clip:
http://www.kleins.co.u​k …PLAYPRODUCT&pro​ductid=321 (external link)
TF posting: here :-)
René ­ Damkot
Aug 26, 2006 01:54 |  #6
Just a thought: Rubber band? (or whatever it's called in English)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
MHP
Aug 26, 2006 02:22 |  #7
yup rubberband, used to do this a lot... works like a charm
Mark
blog (external link)
meeksdigital
Aug 26, 2006 02:29 |  #8
PocketWizards....
Meeks Digital Photography :: www.meeksdigital.com (external link)https://photography-on-the.net …p?p=1686910&pos​tcount=149
joeseph
"smells like turd"
Gallery: 263 photos
Joined Jan 2004
Aug 26, 2006 02:30 |  #9
oh alright, just use a loop of #8 fencing wire and be done with it! :-)
lostdoggy
King Duffus
Joined Aug 2004
Aug 26, 2006 02:35 |  #10
a thin teather string attach to the strap loop to lessen the weight of the cord. They come with every usb flash drive I gotten.
FlyingPete
I am immune
Joined Oct 2003
Aug 26, 2006 04:18 as a reply to  @ joeseph's post |  #11
As a good kiwi male, I have a spool of number 8 under the house, last used it fixing the lawn mower :cool:
Peter Lowden.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Aug 26, 2006 08:58 |  #12
Well, no. Not if it's falling out? Take a pair of pliers & very gently squeeze the end.
I'd add this too. You need some strain relief for when you move too far. Those PC cords fail very easily. ;)
FlashZebra
Aug 26, 2006 11:13 as a reply to  @ PhotosGuy's post |  #13
This is someting that anyone using a PC based flash cord must take to heart.
Even the very best PC cords are still unreliable.
Never depend on one cord. If you need a PC cord for anything, in fact you need at least two (or three). A backup or two is a necessity, not extra fluff.
Enjoy! Lon
jrsforums
Aug 26, 2006 12:58 as a reply to  @ FlashZebra's post |  #14
Ball bungees
http://strobist.blogsp​ot.com …ing-101-ball-bungees.html (external link)
John
1,783 views & 0 likes for this thread, 10 members have posted to it.
906 guests, 162 members online
