I plan to rent a Tamron AF Lens 28-300 f3.5-6.3 to shoot Air Show mount on Canon 5D. Can I expect a good or at least a decent result from it?
eaglesnest Member 189 posts Joined Jan 2006 Location: Ontario, Canada More info | Aug 27, 2006 14:40 | #1 I plan to rent a Tamron AF Lens 28-300 f3.5-6.3 to shoot Air Show mount on Canon 5D. Can I expect a good or at least a decent result from it? www.eaglesnestphotography.com
darkvibe Senior Member 295 posts Joined Apr 2006 Location: Rochester, NY More info | Aug 27, 2006 14:42 | #2 I'm not experienced/educated enough to give you a technical review of the lens but I can tell you that the photos from it are OK at shorter focal lengths. At longer (200mm+) lengths the lens falls off. The photos are pretty soft. If you shoot wide open the photos are very soft. http://www.darkvibe.org/gallery/
form "inadequately equipped" 4,929 posts Likes: 13 Joined Jan 2006 Location: Henderson, NV More info | Aug 27, 2006 17:57 | #3 Why would you rent a consumer all-purpose zoom to put on a full-frame, $3k dSLR? Much better off renting a higher grade, dedicated telephoto zoom...better results, and faster apertures. Las Vegas Wedding Photographer: http://www.joeyallenphoto.com
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | Aug 27, 2006 18:10 | #4 I agree with form. Why put a mediocre lens on a 5D, especially if you're renting. Perhaps something like the Canon 100-400L would be better suited to your needs, and would do justice to the 5D.
Aug 28, 2006 00:32 | #5 Thanks darkvibe,form and crm3371. The only reason I would like to rent this lens is because of its size. I like to have a light weight and compact lenses yet without sacrificing the quality (is there such thing?). www.eaglesnestphotography.com
SkipSouza Cream of the Crop 26,204 posts Likes: 7 Joined Mar 2005 Location: The Left Coast in the Land of Fruits and Nuts More info | eaglesnest wrote: Thanks darkvibe,form and crm3371. The only reason I would like to rent this lens is because of its size. I like to have a light weight and compact lenses yet without sacrificing the quality (is there such thing?). Not really. Bless the recently fallen and their family and friends.
Aug 28, 2006 10:50 | #7 What do you think of Canon EF 70-300 mm F 4.5-5.6 with IS and USM? www.eaglesnestphotography.com
form "inadequately equipped" 4,929 posts Likes: 13 Joined Jan 2006 Location: Henderson, NV More info | Aug 28, 2006 13:17 | #8 Considered a better performer than an all-around lens or any other lens with a 70/75-300mm range, probably, though it also supposedly drops off in sharpness a little towards the long end...perhaps renting "L" glass like the 100-400 would give you better results. Las Vegas Wedding Photographer: http://www.joeyallenphoto.com
SkipSouza Cream of the Crop 26,204 posts Likes: 7 Joined Mar 2005 Location: The Left Coast in the Land of Fruits and Nuts More info | Aug 28, 2006 13:47 | #9 Form is on the right track. I have the EF 70-300 DO IS and love it. It is more compact than the non DO version and has slightly better IQ and terrific IS but it costs TWICE as much. Bless the recently fallen and their family and friends.
papucla10 Senior Member 392 posts Joined Jul 2006 More info | Sep 01, 2006 21:24 | #10 I would get the Canon 70-3000 4.5-5.6 IS USM Canon 50D & 20D - Kodak M1033, Canon 24-105 f/4 L, Canon 28-105 f/3.5-5.6, 430EX II
walturd Mostly Lurking 16 posts Joined Aug 2006 Location: Houston, Texas More info | Skip---
SkipSouza Cream of the Crop 26,204 posts Likes: 7 Joined Mar 2005 Location: The Left Coast in the Land of Fruits and Nuts More info | Sep 09, 2006 15:54 | #12 I have no empirical data that the Kenko is superior to the Tamron and I have both (well one is out on loan now Bless the recently fallen and their family and friends.
walturd Mostly Lurking 16 posts Joined Aug 2006 Location: Houston, Texas More info | Skip Souza wrote: I have no empirical data that the Kenko is superior to the Tamron and I have both (well one is out on loan now ). It is a matter of preference, the Kenko has five elements while the Tamron has four.I did not have either TC when I had my Tamron 28-300 so I can not answer your question with authority. I do believe that if you run the lens wider than 70mm you risk smacking the rear element into the TC. The best bet if you have the Tamron 28-300 is to take it down to your local camera store that has either TC (Canon TC will NOT work) and test drive it. Skip--thanks for the prompt reply about the Kenko
| Latest registered member was a spammer, and banned as such! 2568 guests, 171 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
