I have been looking into geting a set of AB's but just told that they would not be good for rodeo work. This being because of the fan on them and the dust at a rodeo. Has anyone used them in this type of place and have the worked well for you?
HammerCope Senior Member 803 posts Likes: 17 Joined Aug 2006 Location: Nebraska More info | Aug 28, 2006 14:45 | #1 I have been looking into geting a set of AB's but just told that they would not be good for rodeo work. This being because of the fan on them and the dust at a rodeo. Has anyone used them in this type of place and have the worked well for you? Pete
Longwatcher obsolete as of this post 3,914 posts Likes: 3 Joined Sep 2002 Location: Newport News, VA, USA More info | Aug 28, 2006 19:48 | #2 I would have to say - ask Alien Bees customer service about that one. "Save the model, Save the camera, The Photographer can be repaired"
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Aug 28, 2006 19:54 | #3 I can't see the dust being a serious problem if you blow it out after a session. Ordinary dirt is not very conductive and should not harm the circuitry in the flash unit. It would be a good idea, however, to talk to AB's Customer Service to get their opinion too. Skip Douglas
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | SkipD wrote: I suspect you would need the most powerful lights you can afford for rodeo work, as the distance between the flash and the subjects won't be very close. The best setup would be a whole mess of high powered flash units mounted up high (on light poles?) with radio receivers on each to trigger them. You'd use a matching radio transmitter on the camera to send a signal to the receivers. What skip said. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member is semonsters 1706 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
