I tried my hand the other day while sitting at the marina at spot metering and wanted to know a few things regarding metering differences.
Is there a technique to multi-spot metering? I tried it and this was the difference.
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
I found the Eval was more accurate or at least exposed better. Does it matter in the sequence of capturing the 3 metering points?
