Thread started 30 Aug 2006 (Wednesday) 11:01
Best file type for prints jpg or tiff
Phillydigishooter
Aug 30, 2006 11:01 |  #1
I have read several book on digital photography. They all recommend after downloading the photos and post processing save the file in "TIFF" format not "JPG" One author claims "JPG" format loses minute quality each time it is opened. Also the best format for prints is "TIFF."
What file format type do you use for prints?
Bob
Canon G3. Canon 350D, efs 18-55mm, efs 75-300mm
Hellashot
Joined Sep 2004
Aug 30, 2006 11:37 |  #2
That is wrong. When you SAVE a jpg more than the initial save it degrades the image quality. Opening a file never corrupts a file. TIFF is better to print from if you can.
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
SkipD
Joined Dec 2002
Aug 30, 2006 13:40 |  #3
The TIFF format is usually not compressed, and if you use a compressed TIFF format, it is a lossless compression. JPG files, on the other hand, are always compressed, though one can choose how much they are compressed. The compression is a lossy thing as well. Once information in an image is lost via JPG compression, it can never be recovered.
If you take even the highest quality JPG file and do the following sequence of three steps 20 times, you will easily see the corruption of the image: 1) Open the JPG file, 2) Save the JPG (back to the original file), 3) Close the JPG file.
To see the difference radically, make a copy of the original JPG file to do the 20-cycle test on and then you can compare the original to the one you saved 20 times. There will be a huge difference.
The test above shows why you do NOT want to open, edit, and save a JPG more than once or possibly twice. Note the test above does not even include any editing steps.
Skip Douglas
Phillydigishooter
Aug 30, 2006 17:35 |  #4
Thanks everyone for your comments
Bob
Blue ­ Deuce
"I don't say anything witty"
Aug 30, 2006 18:35 as a reply to  @ SkipD's post |  #5
I have always known this but tried your test since I am bored and rained in from tropical storm Ernestso. I saw a slight degradation after 20 saves.
What I can't figure out is why did my chosen file started out at 403kb and wound up at 411kb at the 20th save ?
tim
Light Bringer
Aug 30, 2006 20:14 |  #6
For prints save a copy as a Q10 or Q12 JPG, TIFF is unnecessary and they're huge. Make sure you save a copy in psd or tiff if you plan to edit it again.
Tareq
"I am very lazy, a normal consumer"
Aug 31, 2006 07:25 as a reply to  @ tim's post |  #7
I have RAW files of most of my photos and i save the RAW files only, when i save i can choose between jpeg or tiff, but nowadays i try to use more tiff saving files as it is much better in IQ than jpeg and no affected with many save repeating, so i can produce jpeg from RAW or tiff only and i don't edit jpeg several times when needing, i just pp RAW or Tiff, and i will try to pring my most or all photos by tiff, no problem with size as i got lots of DVD's to copy and burn in (DVD+/-RW) so i can go to print it to lab studio without fear of losing quality.
Galleries:
http://hamrani.deviant​art.com/gallery/ (external link)
Facebook (external link)
Vince ­ Ecosse
Joined Feb 2006
Aug 31, 2006 12:02 |  #8
I have something else on my computer.
I use DPP to process my raw files. I have converted the same raw file to tiff and jpeg, using 8 bits tiff and best quality jpeg. And both images are now not exactly the same in terms of colour, when looked at on my computer. So I assume it would be the same on paper. Can someone explain?
Body: EOS 5D
Lenses: 16-35f2.8, 35 f1.4, 85 f1.8, 135 f2,
Flash: 580EX, 430EX.
gasrocks
Aug 31, 2006 23:26 |  #9
In the begining, your saved .jpg and .tif might look the same and print about the same. Problem is down the road. Tif's do not change in size = nothing lost. Jpg will change in size every time you save = not your original pix, just a good guess about what it looks like. My favorite "archival" formats are .tif .png and/or .jp2
JaertX
Aug 31, 2006 23:36 |  #10
The largest I have printed anything is 16x20. I've printed 16x20's in both TIFF and JPEG and the difference is so minute that it isn't worth the time uploading the TIFF file to my lab's website. I'd say do a test...print two of the largest sizes you intend to print on a regular basis. Shoot RAW, convert one to TIFF and one to JPEG, do all your tweaks and print them. I'd bet from a normal viewing distance you won't see a difference.
Jason - I use Canon and stuff
tim
Light Bringer
Sep 02, 2006 04:49 |  #11
I just did some experiments, take a look on this thread.
kevin_c
Sep 02, 2006 05:17 |  #12
After ALL PP work I always save as tif for archive, but any files for printing I just resize/crop as required and save as Quality 12 jpeg's and either upload them or put them on CD - I would defy anyone to tell the difference between this and a tif file that gets printed with the naked eye.
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
1,769 views & 0 likes for this thread, 10 members have posted to it.
2453 guests, 105 members online
