Thread started 30 Aug 2006 (Wednesday) 11:08
dust inside the lens?
sandro9mm
Aug 30, 2006 11:08 |  #1
I've some dust in the lens... is it possible to send it for a cleanup? my warranty is over, so how much will that be?
Photography Tips (external link) - Learn photography now!
Famous photographers (external link) - Video Interviews, photos, biography
My gear (external link)
nitsch
Aug 30, 2006 11:13 |  #2
Let me guess, it's the 17-85 right? That lens is a real dust sucker! Whichever lens it is, if its just a few specks you can see behind the front element then it's highly unlikely to affect the IQ so don't worry about it would be my advice.
chtgrubbs
Joined Jul 2003
Aug 30, 2006 11:13 |  #3
Dust often migrates into lenses, especially zooms, which are not sealed. It isn't detrimental unless there is enough to reduce light transmission, so I would probably just ignore it.
sandro9mm
Aug 30, 2006 11:32 |  #4
nitsch
yes :D correct, that's 17-85, I use it often... so I guess that's the reason... :P
so I'm ignoring it :P
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Aug 30, 2006 16:46 |  #5
Unless you shoot in a vacuum, most if not all lenses that zoom out will eventually suck in some dust. It's really shouldn't affect the optics so I'd just ignore it. Even if somehow managed to clean it off, you'd just get more anyway.
Gallery: http://tomyi.smugmug.c​om/ (external link)
sandro9mm
Aug 30, 2006 16:48 |  #6
Tee Why
that's not quite correct, L series have sealing and it does help to keep away dust...any L series zoom will be dust free :)
Ianfp
Aug 30, 2006 17:00 |  #7
When I had my 17-85, I took it apart and cleaned it!
But I do not recommend you do this unless you have experience!
Ian
Nikon D850, 85mm f/1.4G
5D2
EF17-40 f/4.0 L, EF135 f/2.0L EF200 f/2.8L
EF24-105L, EF100 f/2.8L Macro. EOS-M, 22mm f/2
Hasselblad 500C/M, Planar 80mm f/2.8
Jon
Joined Jun 2004
Aug 31, 2006 14:53 as a reply to  @ sandro9mm's post |  #8
sandro9mm wrote:
Tee Why
Not all L lenses have sealing.
Jon
Cocker Spaniels
illy
Aug 31, 2006 14:55 |  #9
You will generally find that all un-weather proof sealed lenses will accumulated dust over time. Try this; when it gets dark, grab a torch and shine it through the lens (wide open) onto a nearby wall, and see if the dust shows up. If not then don't worry about it, if it does show up heavely then maybe send it off to canon but I think the repair may cost more than the kit lens.
600D, 17-50, 50, 60, 100, 70-200, 430EX
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Aug 31, 2006 23:20 as a reply to  @ sandro9mm's post |  #10
sandro9mm wrote:
Tee Why
In theory, but the OP has a 17-85 and even the L lenses that zoom in and out will suck in some dust despite the sealing. That's why the 100-400L is nicknamed the dust pumper.
You should see all the dust on the front element of my bigma, it's just covered. Can't see one of them on a shot though. Stop your worrying and go out and shoot more.
remixity
Sep 01, 2006 13:11 as a reply to  @ sandro9mm's post |  #11
sandro9mm wrote:
Tee Why
Not true. My 16-35mm f/2.8 and 70-200mm f/2.8 IS came with dust inside :rolleyes:
sugarroo
Sep 14, 2006 14:58 |  #12
so does anyone have an idea on the $$ to have canon clean it?
thanks
Canon 20d, Canon 300d, Sigma 70-300 4-5.6, Canon 28-105 3.5-4.5, Canon 18-55, Canon 17-85, 430ex.
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Sep 15, 2006 03:27 as a reply to  @ sugarroo's post |  #13
I have just received back from Canon servicing an EF-S 17-85mm IS USM.
3 weeks after purchasing the lens, I noticed a large fleck - quite likely dandruff (mea culpa). Four months saw 21 countable particles, the fleck and two hairs. At 11 months there were 28 countable particles, and it was just too much. The fleck was firmly fixed to the optic, the others moved around between optics and bellows.
9 days away, including 2 for courier, and NZ$100 (US $65).
I asked about replacing the seals - the lens was returned with a note saying that there are no seals.
No! Really? I am surprised!:confused:
So, budget $100 annually for a clean.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
1,683 views & 0 likes for this thread, 10 members have posted to it.
2881 guests, 176 members online
