Thread started 03 Sep 2006 (Sunday) 11:09
A suitable head monopod head for the Manfrotto 680B?
fi20100
Slightly late
Sep 03, 2006 11:09 |  #1
I just picked up the Manfrotto 680B monopod. Now I’m looking for a sensibly priced monopod head.
One possibility that I’ve seen is the Manfrotto 3232 Swivel Tilt Monopod head. I understand that the weight capacity of it isn’t great, but at the moment I have no heavy lens, and the heaviest I will ever get would probably be a 24-70mm f/2.8 L.
Any suggestions?
-Fi20100
Stefan
5D3, 5Dc, 5Dc, 40D + 17-40L, 24-70L, 70-200L, 50/1.4, 85/1.8, 100L Macro and some other stuff.
flickr (external link), 5∞px (external link)
SkipD
Joined Dec 2002
Sep 03, 2006 12:24 |  #2
I prefer to use a Bogen/Manfrotto 486RC2 ball head on my 680B monopod. It seems that quite a few folks on the forums have followed my recommendation (or have thought of it themselves) and like the combination. It allows you a lot of versatility that the one-way tilt head won't give you.
Skip Douglas
fi20100
Slightly late
Sep 03, 2006 12:47 |  #3
Ok. I did consider a ballhead at first, but that I thought that it would be harder to handle on a monopod. I guessed that a ballhead would work better for a tripod.
Since I don’t have any experience of a ballhead, my perception might be very wrong ;)
Thanks for the recommendation though. I will defenitly think of it as an option.
-Fi20100
Stefan
Jon
Joined Jun 2004
Sep 03, 2006 15:24 |  #4
I also prefer the 486RC2 on my monopods. Tried the 3232 and it just didn't cut it. I prefer the multiple degrees of freedom I have with the ball head.
Jon
Cocker Spaniels
dewmuw
Joined Jul 2002
Sep 03, 2006 15:25 |  #5
Doesn't that depend on what you are going to be using it for? I have the 488RC2 and it's great.
Damian Waters
www.drumimages.co.uk (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Sep 03, 2006 16:32 |  #6
I do prefer the 3232, and note that the rated weight capacity is much lower than reality. It works pretty well with the EF 500mm. I have an Arca QR on it. But yes, it depends on how you use it as to whether the tilt only will be adequate. Many use monopods with no head for the big guns.
CDS' HOT LINKS
fi20100
Slightly late
Sep 04, 2006 01:39 |  #7
Thanks for all advices. Perhaps the best thing would be to get both the 486RC2 and the 3232. When I sometimes get a better tripod (have some cheap Velbon now that I got for my handycam a long time ago), I guess it will be good to have both heads.
Stefan
lungdoc
Sep 04, 2006 06:58 |  #8
I would recommend a 488RC2 for tripod use because it has a separate panning control compared with 486. On a monopod that's not really necessary since you can spin the whole "stick". I do like the 486RC2 on my 480B (thanks to the forum's recommendations); it's a good size/weight and the ballhead allows use of monopod in various angles so you can use your feet as the rest of the "tripod". I just got an extra RC2 plate adapter that screwed into my circa 1982 old tripod's 3 way head allowing me to use the quick release plates and it works well.
Mark
My Smugmug (external link) Eos 7D, Canon G1X II, Canon 15-85 IS, Canon 17-85 IS, Sigma 100-300 EX IF HSM, Canon 50mm 1.8, Canon 85mm 1.8, Canon 100mm 2.8 Macro, Sigma 50-150 2.8, Sigma 1.4 EX DG , Sigma 24-70 F2.8 DG Macro, Canon EF-S 10-22, Canon 430EX,
fi20100
Slightly late
Sep 04, 2006 07:14 |  #9
I just think the 486RC2 is more sensibly priced. I rather save a bit on the tripod / monopod equipment, and put a bit more in the lenses. In a perfect world, price would not be an issue ;)
Stefan
lungdoc
Sep 04, 2006 07:33 |  #10
In that case I'd suggest either just getting a 486 and using for now for both tripod and monopod or just getting a 3232 for monopod and get 488 later for tripod.
Mark
fi20100
Slightly late
Sep 04, 2006 08:12 as a reply to  @ lungdoc's post |  #11
Yep, either or seems to be a good idea.
I understand that photography is a very long-term hobby. Investing in good equipment should be done over a long period of time, as one’s skills improves and needs grow larger. However, in the beginning, there are so many things (lenses, flashes, etc) that seem appealing (and visiting this forum does not help). I guess it will be either the 486 or the 3232 for a starter. Thanks everybody for the advices!
-Fi20100
Stefan
BearLeeAlive
All butt cheeks and string.
Sep 04, 2006 18:09 |  #12
One more vote for the 486RC2. I use my monopod lots for macro and you can't beat it for all the twisted positions you need to get into while using the monopod. Can't beat the price either.
-JIM-
SolPics
Joined Jun 2005
Sep 05, 2006 00:02 |  #13
I converted the 3232 to Arca Swiss type of head and it works great. Here is a link on converting http://reallyrightstuf​f.com/tutorials/monopo​ds/index.html (external link)
SolPics
Cannon 5D 30D, 50 f/1.4, 85 f/1.8, 135 f/2.0 L, 200 f/2.8 L, 500 f/4.0 L IS
17-40 f/4.0 L, 24-70 f/2.8 L, 70-200 f/2.8 L IS, 100-400 f/4.5-5.6 L, 580 EX,
Gitzo Tripod, all sorts of bags.
Mat ­ Fitzsimmons
Sep 05, 2006 03:18 |  #14
Heh, I've just mounted a RRS screw-type clamp directly onto the top of my monopod (a Gitzo 1588 ) - with no head at all. Haven't found it to be a problem at all yet, except if I want to shoot up at a significant angle (which I pretty much never do).
Mat Fitzsimmons
Canon 5D, other Canon stuff
fi20100
Slightly late
Sep 05, 2006 03:57 |  #15
Well, usually it’s good to be able to angle the camera separately from the angel of the monopod. To keep the monopod really still, you want to use yourself and the monopod to form a tripod so to speak. This usually means that you are not trying to keep the monopod exactly vertical, but slightly angled towards yourself. In this case you really need to have some kind of a head that will let you angle the camera differently from the monopod.
-Fi20100
Stefan
6,410 views & 0 likes for this thread, 10 members have posted to it.
1400 guests, 110 members online
