Greetings all,
About eight months go i got a 1ds mark ll and have done nothing but shoot in raw in evaluative mode and correct my own prints.
Now I've got a school portrait gig where the lab only wants JPEG with custom white balance. They get thousands of files and want as nearly a "perfect" file they can get. I decided to use the one shot Digital Calibration Target because the lab wants as nearly a technically perfect file as possible.Since its coming up in a couple of days i wanted to post....
1) Is the three strip black, gray, white target better to use, as the inventor, Mr. Pierce (sic?) claims, than using just white? Or at this point should I just use white and hope for the best?
2) I didn't quite get Mr. Pierce's instruction on the accompanying DVD on setting the best histogram... The histogram should show 3 evenly spaced spikes to indicate perfect exposure, right? I should increase/decrease over optimum exposure indicated in the viewfinder until I get those 3 evenly placed spikes in the histo? Don't quite have the faith in overexposing (with ttl metering) on the card to get a good histogram...advice appreciated...
3) Once AWB is set, it stays in the camera even when you change cards and you are
always shooting in AWB thereafter, right?
Finally, these are little kids, many dark complected but wearing stark white dresses. With evaluative metering, I noticed faces were under exposed and dresses were good. Has anyone used spot metering on faces with AF, holding the shutter down halfway, recomposing and shooting?
Thanks so much for your comments...
Trax
