Was wondering if anyone has any experience at using a 300mm f2.8 as a macro lens? After investing such a lot of money in a lens i would like to try and get the most out of it and wonderd if anyone had used extension tubes etc and got good results.If i stack the TCs i have i get quiet a good result but the minimum focusing distance is still about 8 foot from the subject.
![]() | HTTP response: 404 | MIME changed to 'text/html' | Byte size: ZERO |
Thanks for any advice you can give.
The problem is that that lens is very heavy, and very large. For dragonfly/butterfly/damselfies it might be ok, but it's very cumbersome and you'll almost certainly have to use a monopod at the minimum, most probably a tripod.
like using a wideangle on a close portrait, except for bugs! I don't think there'd be too much vignetting on a 1.6x crop... of course I might be wrong... Anyone actually tried it??
