The actual photo taking process varies so much depending on situation, so I'll skip that and start with a card full of images.
1. Put the card in the card reader and copy all files to folder on desktop.
2. Copy this directory to a remote drive.
3. Set the card aside with a small post-it it with the shoot details.
4. Move all the image files to a single folder.
5. Open Bridge and browse to that folder.
6. Batch rename all files in Bridge.
7. Start coding junk files for deletion.
8. Hide flagged files.
9. Second Pass for junk.
10. Put all the junk files in a folder called 'almost junk'.
11. Go through the remaining files and give good, better best ratings.
12. Anything unlabeled gets thrown in the 'almost junk' folder.
13. Combine the good and better and send any that don't make the cut to the almost junk folder.
14. Now I have my initial keepers that are worth developing to find out if they really are keepers.
15. Open in ACR and make general adjustments to WB, Exposure, etc.
16. I often apply settings to many images at once, this is just a quick and dirty raw setup.
17. Open all in ACR and convert to 8 bpc sRGB .jpg in the same dir as the raws.
18. Repeat steps 7-14, except I just flag the good raw file, and delete all the .jpgs when I'm done.
19. Adjust each image in ACR.
20. Let the images simmer for a day, since I'll need "fresh eyes" to finalize ACR settings.
21. Get all the ACR settings finalized, and save as 16 bpc .psd in some large gamut colorspace of my choice, and another folder called dev.
The rest of the steps are actions that point to scripts that are usually run as a batch, unless there is an issue with the edit. I have a a bunch of actions prebuilt that I snap together into one big action for batching groups of similar images. Sometimes, I have to backtrack and change the intensity of an effect, but generally the process is the same and looks like this:
22. Create surface masks, make selection, create layer mask, run noise reduction.
23. Inspect.
24. This is where I clone out goobers, do some controlled burn and dodge using a 50% grey overlay layer, or any other weird editing like this.
25. Inspect.
26. 1st pass of sharpening - I like to use modified TLR Capture scripts for this.
28. Inspect. Sometimes this where the really hard to spot goobers appear, so they get zapped here.
29. If there are any other issues with the picture, this where that gets handled. It's also when I'll convert to L*a*b color mode, if I want to add a certain "look" to the picture, or just to add pop with a Curves adjustment layer. Any other "creative editing" happens at this point.
30. 2nd pass of sharpening - TLR Creative sharpening. Interesting tidbit: in the quest for sharpness, a little bit of gaussian blur in the right places can go a long way. Think "unsharp mask" the hard way.
31. Final inspection.
32. Start the archive process.
33. Basically, a flattened .psd file gets put in about 3 redundant locations - some off-site.
34. Now I can go ahead and reformat the card. I'll go through the 'almost junk' ocassionally, and purge it.
Now I have nice finished, 16 bpc images ready for web or print. Well, not really. Here is the "weberize" process:
35. Using Image>Resize, to 800x533, or some other arbitrary dimension. Use Bicubic Sharper.
36. Convert to sRGB colorspace.
37. Convert to 8 bpc mode.
38. Save as .jpg quality 12.
39. Upload to hosting site.
40. Start a new topic here and keep hitting F5 when on the "Show new replies to your posts" page.
I think I got it all. If I missed something big, let me know and I'll fix it. I do realize it is a somewhat radical workflow, but it is cantered around quality at every step. Too bad I can't get more quality at the "press the shutter"step.
