Thread started 07 Sep 2006 (Thursday) 22:25
how do i get these light trails?
dro524
Sep 07, 2006 22:25 |  #1
how do I get a photo to look like this:
IMAGE: http://img237.imageshack.us/img237/279/742149851lma6.jpg
The lights are "trailing" yet the subject stays in focus.
I am a beginning photographer and I would like to learn all i can about everything
lostdoggy
King Duffus
Joined Aug 2004
Sep 07, 2006 22:45 |  #2
slow shutter and shakey hands.
Wilt
Sep 07, 2006 22:50 |  #3
As lostdoggy says. It generally requires fairly dark scenes, so that the lights in the amps etc. will expose, but the equipment that they are in is left somewhat 'invisible' except for the light provided by the brief burst of light from the flash which allows the equipment to be seen, but without blurred edges because they were previously dark.
lostdoggy
King Duffus
Joined Aug 2004
Sep 07, 2006 22:54 |  #4
I think it also needs to have second curtain sync for it work.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Sep 07, 2006 22:54 |  #5
If you use flash with a slow shutterspeed when the room light is bright enough (or you have the iso pumped up) you will get this ghosting effect. It can be pretty cool for the right type of shots.
Note that if the room is dimly lit and flash is the main source of light then you can set the shutterspeed pretty low and you won't see any ghosting since the flash burst is so quick.
Bob
Wilt
Sep 07, 2006 23:12 as a reply to  @ Bob_A's post |  #6
bob, if the equipment power indicators are sufficiently bright, and the lens is open enough, they WILL register in the image by themselves. Separately the flash provides the main illumination for the equipment itself. Where the ambient illumination is bright enough, while the shutter is open even this will register somewhat, and if the camera is shakey you get blurry ghosting (like the upper amp and speaker in the photo) but where the ambient illumination is low only the flash exposure will register (as in the lower parts of the amp and speakers and equipment packing boxes)
Not in the case where you can't really tell where the motion starts and where it ends in the path because telltale clues are missing. In this particular you could have flashed first, then moved with an open shutter, or you could move with the open shutter first and then flashed. (car headllights behind the car moving toward you = rear curtain, vs. headlights in front of the car moving toward you = front curtain) The end result would be similar in either case with this photo since the equipment doesn't move, and we have no other clues to figure this one out.
lostdoggy
King Duffus
Joined Aug 2004
Sep 07, 2006 23:24 |  #7
This is just a maybe:
1st curtain capture the trailing liht on the equipt.
2ndcurtain and flash capture the stop action of the person.
Th overall scene had to be dimly lite to capture the trailing lite and the flash freeze and capture the rest.
Bob_A
Gallery: 48 photos
Joined Jan 2005
Sep 08, 2006 08:14 as a reply to  @ Wilt's post |  #8
Exactly, which is what I meant, but you have stated it more clearly.
Bob
dro524
Sep 08, 2006 20:39 as a reply to  @ Bob_A's post |  #9
ok so basically what i have to do is use the flash and turn down to a slower shutter speed (1/15th?) and...shake my hands?
A01
Sep 09, 2006 01:59 as a reply to  @ lostdoggy's post |  #10
Thats what im thinking, there are SLIGHT signs of the guy moving there so im guessing thats what they used.
Aaron
FOR SALE
- My Gear - Some of my Work (external link) - POTN Aussie Club -
Wilt
Sep 09, 2006 06:33 as a reply to  @ A01's post |  #11
All we know is that
A) the camera was moving left to right with second shutter synch, and the guitarist was moving right to left at the same time, there was low light down low and more light up higher in the picture, OR
B) the camera was moving right to left with first shutter synch, and the guitarist was moving left to right at the same time, there was low light down low and more light up higher in the picture, but
we have no clues about which of the above two scenarios applies, though. Both are possible.
dro524
Sep 09, 2006 17:15 as a reply to  @ Wilt's post |  #12
I just want to know if the trails are possible with just a 35mm camera and a flash. Cause that is all i have. Here is another picture of what i am trying to get at:
IMAGE: http://img101.imageshack.us/img101/2648/319169134lqd6.jpg
PacAce
Joined Feb 2003
Sep 09, 2006 17:22 |  #13
Yes, it is but you won't be able to see the results of your exposures until you get the film developed.
...Leo
dro524
Sep 09, 2006 17:29 as a reply to  @ PacAce's post |  #14
i know that
PacAce
Joined Feb 2003
Sep 09, 2006 17:42 as a reply to  @ dro524's post |  #15
dro524 wrote:
i know that
Sorry. The point I was trying to make is that you should try to figure out what settings would be best to use before you go shooting with the film so that you'll have a better chance of getting some "successful" shots. I just tried with my digital camera and it's not as easy as it seems. I had to do it more than a couple of times to not just get the camera settings right but to get the a reasonable light trail as well as getting the flash to be just right, too. Too much flash and it ruins the whole shot. :)
...Leo
1,632 views & 0 likes for this thread, 6 members have posted to it.
1711 guests, 105 members online
