Thread started 08 Sep 2006 (Friday) 13:36
My Thoughts About UV Filters
aero145
Sep 08, 2006 13:36 |  #1
Hello fellow POTN members.
I was just thinking about UV-Haze Fliters.
Am I right that it is better to not use them when there's no haze, or when the lens hood is on...? As I have one 67mm UV filter and I have 2 67mm filter mount lenses... So wouldn't it be more clever to just switch filters depending what lens I'm using? Instead of having them on all the time...
Some people say they damage the quality.
Some say they don't.
I don't want the 'accident' loss-of-image quality.
So should I use them as little as possible?
Sorry if the post is hard to read.
Thanks,
Aero145
EOS 5D Mark II | EF24-105 f/4L IS | EF100-400 f/4.5-5.6L IS | EF200 f/2.8L II | 580EX | Manfrotto 055xProB + 808RC4, and 679B
Le Gear List
Fureinku
Sep 08, 2006 13:41 |  #2
I only remove mine if even with the hood on, i get flare... when i shot fireworks, i had to remove it
Gear List | Wish List |
aero145
Sep 08, 2006 13:43 |  #3
Understand.
Le Gear List
TheSteveMadden
Sep 08, 2006 13:47 |  #4
You must be new around here :lol:
This topic has come up quite a bit and there are advocates (zealots) on either side. I prefer no UV unless needed for real haze, but others want the extra peace of mind.
Check this thread and this poll.
Steve
Canon EOS 5D Mark II, 30D, XT, EF 24-70 f/2.8L, 50 f/1.4, 85 f/1.8, other EF lenses, 430EX, several 580EX II's, Pocket Wizard Plus II's, lighting supports and modifiers, etc etc etc
Website (external link)
Jon
Joined Jun 2004
Sep 08, 2006 15:26 |  #5
I use 'em for protection - flying debris from high winds/prop or jetwash, dog noses, and other routine hazards of my photographic subjects.
Jon
Cocker Spaniels
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Sep 08, 2006 15:30 |  #6
I leave it on, but during high contrast settings like night shooting or shooing into suns, etc, where I expect flare, I take it off.
Gallery: http://tomyi.smugmug.c​om/ (external link)
Fureinku
Sep 08, 2006 16:17 |  #7
i just keep on on because, if i had to clean the outer element, id rather scratch a Filter then the front element if i messed something up, or it there was something sharp on my microfiber towel, also, i get clumsy sometimes when removing/applying my lens cap with the hood on
vjack
Sep 08, 2006 16:25 as a reply to  @ Fureinku's post |  #8
I don't use them at all. I'd want one if I was working in blowing sand, salt spray, or a similar situation. Under normal conditions, I see now reason to use one.
Canon 20D
Canon EF-S 10-22mm f/3.5-4.5 USM
Sigma 18-125mm f/3.5-5.6 DC
Tamron 28-75mm f/2.8 XR Di LD
Canon EF 50mm f/1.8 II
Canon EF 70-200mm f/4L
Canon EF 100-400mm f/4.5-5.6
L IS
Canon Speedlite 430EX
Manfrotto 3021BPRO; Kirk BH-1 ballhead
Canon Pixma 4200
< see my gallery (external link) >
coreypolis
Sep 08, 2006 16:27 |  #9
don't use them at all. stuff is insured, so if something happens, its no skin off my back. reducing image quality isn't worth the investment. Polarizng filters are the only thing that go infront of my lens.
Photographic Resources (external link) || International Photo Journalist (external link)
Blog (external link)
Seattle Wedding Photographer - Corey Polis Photographer (external link)
steved110
Sep 08, 2006 16:36 as a reply to  @ coreypolis's post |  #10
I always use UV filters - mainly to keep the front element of the lens clean. I'd rather clean a filter than the lens itself!
buy the best quality designed for digital multi coated filters you can afford - Hoya and B & W are respected, and you will not notovce any image degradation at normal print sizes. You do have to keep filters clean in high contrast situations though!
Canon 6D
Canon EF 50mm f/1.4 , Canon EF 85mm f/1.8 Canon EF 100mm f/2.8 macro
CanonEF 17-40 f/4 L Canon EF 24-70 f/4 IS L and 70-200 f/4 L :D
Speedlite 580EX and some bags'n pods'n stuff
aero145
Sep 08, 2006 16:40 as a reply to  @ steved110's post |  #11
Thanks for the replies, people!
When I'll sell the Hoya-filter-67mm lens I have, I'll buy one B+W Haze filter for the only 67mm lens I'll have, to be used in: Conditions which include some materials in the air, hazy conditions, and when I don't use the hood.
Just keep the filters in their boxes in the bag, so when I have to use them, they're ready. :)
I'm then planning to buy a 77mm Polarising Filter. Is polariser needed on a telephoto lens, or just for a wide angle one?
Regards,
Aero145
Le Gear List
Jon
Joined Jun 2004
Sep 08, 2006 17:21 |  #12
Polarizers are for reflection and backscatter control. They're situational no matter what lens you're using.
Jon
Cocker Spaniels
Photorebel
Sep 08, 2006 17:24 as a reply to  @ Jon's post |  #13
If you are going to use filters, get good quality (Hoya, B+W). They are pricey, but cheaper than replacing a front element on a lens.
I use B+W on my 70-200 f/2.8 and 300 f/4L (for protection). There is no loss of image quality that I can detect.
-Jeff
5DIII, 60D, 50 f/1.2L, 85 f/1.8,100 f/2.8L, 24-105f/4L
480 EXII
Titus213
Sep 08, 2006 17:35 |  #14
Anyone ever hear of someone needing to replace a front element?
Dave
Perspiring photographer.
aero145
Sep 08, 2006 17:37 as a reply to  @ Jon's post |  #15
I thought they were mostly used for getting nicer contrast in clouds when there is also blue sky behind them. :-P
Le Gear List
1,870 views & 0 likes for this thread, 14 members have posted to it.
2568 guests, 171 members online
