My dad spent a portion of his childhood in Ionia Michigan. His father was a master craftsman whose skills were much in demand. He was also a bit of an entrepreneur, and had careers as diverse as running a lumber mill, custom building automobile bodies, carpentry, and so forth. Dad was born in 1903, and things were very different back then. When you moved, you didn’t call Mayflower, toss all your earthly goods in the back of an enormous truck, and merrily head off to your new homestead. Very often, you took only the most essential of belongings and left the rest behind. That was the case with Dad. Grandpa announced that the family was moving, probably the same day, and off they went.
Fast forward about fifty years. Dad was a senior engineer at McCullouch Corporation, and was interviewing a potential new hire. In the course of making small talk, they were discussing their childhoods, and learned that they had both lived in Ionia. Considering that Ionia was just about two blocks long back then, just a dot on the map, that was coincidence enough, but as they talked, they realized they lived on the same street, and in the same house. That man’s family had moved in after Dad’s moved out. Carrying it one step forward, Dad asked if he had found his bicycle which he’d left under the porch. He said he had, and he had ridden it for years.
