nitsch wrote:
If you are shooting at 1:1 it doesn't matter wether you are using 60mm, 100mm or 180mm macro lenses, the DOF will be identical only the working distance will change.
Though this is not exactly true because of the nature of lens designs-floating element macro lens optics-the biggest two effects of going to a longer focal length macro are:
1. As mentioned, Working Distance (lens front element to subject distance) does increase significantly as focal length increases, out to about 200mm.
2. The macro out-of-focus image background gets "more absolutely blurred"- more pleasingly blurred-as focal length increases.
So, no, moving to a longer macro will not increase DoF appreciably, unless you frame the image differently.
DoF is a mathematical concept, because it depends on circle of confusion and viewing distance, as much as it depends on a subject distance/lens focal length. So, for all practical purposes, if you are happy with the excellent EF-S 60mm, then:
1. Carry more light with you, carry flash, carry reflectors, and/or use longer exposures so you can increase the Aperture to f/16+. I have shot this lens at f/22+, and the DoF gain exceeds the diffraction loss of sharpness. Not only does flash allow you to use f/16, but the flash will "freeze" motion blur at lower shutter speeds when the flash is a dominant light source.
2. Pay close attention to the angle the camera is pointed relative to the plane of focus on the subject where you want the maximum DoF to be.
3. Use a smaller APS-C sensor camera. The Rebels/20D/30D have more DoF than larger sensor cameras like the 1-D or 35mm.
4. Try and get the background of your image separated, to be further away from the foreground subject. Then the perception of blur background to sharper foreground will give viewers a better impression, even if your DoF in compromised.
Jack
