28-300mm IS Zoom.. Canon 5D & 580EX Flash.. What is the best settings for flash and camera for high school basketball. look forward to your help.
marions Member 72 posts Joined May 2006 More info | Sep 12, 2006 21:46 | #1 28-300mm IS Zoom.. Canon 5D & 580EX Flash.. What is the best settings for flash and camera for high school basketball. look forward to your help.
ACDCROCKS 321 123 33 2,931 posts Likes: 1 Joined Sep 2005 Location: in your attic More info | Sep 12, 2006 22:00 | #2 It varies from gym to gym. I would use 3200 iso and the highest aperature you can with that lens. Use 1/225-1/325 for shutter speeds canon weight
Sep 12, 2006 22:30 | #3 Still need to know flash setting.. Brand new just took it out of the box today.. figure someone would have the answer.. Thank you
Sep 12, 2006 23:24 | #4 |
Sep 12, 2006 23:27 | #5 |
superdiver Cream of the Crop 9,862 posts Likes: 5 Joined Jan 2006 Location: Ketchikan Alaska More info | Sep 13, 2006 14:52 | #6 I just dont like basketball pictures with flash....but thats just me... 40D, davidalbertsonphotography.com
PhillNorman Member 174 posts Joined Apr 2006 Location: Newark Delaware More info | Sep 13, 2006 15:06 | #7 Marions i wouldnt use flash in the Gym since it would be to bright...try using 3200 as your ISO that would help alot...may i suggest getting a little closer also...If this is your first time i would good job... PhillNormanphotography
coreypolis Cream of the Crop 6,793 posts Likes: 4 Joined Mar 2005 Location: Mercer Island, WA More info | Sep 13, 2006 15:10 | #8 Permanent banwhile the 28-300 is a great lens for something, low light photography is not one of them. If you can get a fast prime like a 85mm f/1.8 or the 1.2L, or the 135 f/2L, they would be much better suited for that kind of photography Photographic Resources
Sep 13, 2006 22:31 | #9 maybe when Dell finaly ships my 70-200 2.8 IS, that I was supposed to get on the 8th, I can get rid of the flash. Thank you for your input.
Croasdail making stuff up More info | Sep 14, 2006 05:15 | #10 The shots are pretty small... so it's hard to say. But from what I can see, it looks like the flash was working pretty good for you. If you could post larger examples, that would be great. There are all kinds of ways to soften the flash, and the lens you are using has a very usable range. It just isn't commonly used because in many plances flashes are not allowed. But if it is .... no reason to stop. Being able to go wide under the basket is awsome... the range of your lens is not an issue. Post some larger examples and we can go from there.
abdallas Hatchling 3 posts Joined Oct 2005 Location: Lynden, Washington More info | Sep 16, 2006 21:41 | #11 I found quite a bit of success with the 85mm 1.8 and the 50mm 1.4 during the hoop season last year. The 70-200mm 2.8 also works great. Even with these lenses, sometimes I will bounce the 580 of the ceiling or nearby wall to cut down on direct flash at players.
| Latest registered member is Frankie Frankenberry 1096 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
